engine temperature - Mercedes-Benz Forum
LinkBack Thread Tools
Old 01-05-2017, 09:57 AM Thread Starter
Date registered: Jan 2017
Smile engine temperature
Hi,
I would like to ask about the engine temperature.
My car is a 2015 year's A250. The normal engine temperature is around 90C.
And the warm up time is normal, it usually takes less than 10 minutes to achieve 90c (outside environment temperature is 20c).
When I drive in city, the engine temperature can maintain at 90C. And while i drive in highway (speed around 80km/hr to 110km/hr). The engine temperature can maintain at 90c.
But when the speed goes up to 120km/hr above, the engine temperature drops to 80C or even slightly below 80C.
Just want to know is it normal? Or should it has a problem on the thermostat?
Thanks for your answer in advance.
izzyyuen is offline
Old 01-05-2017, 10:39 AM
Coddger's Avatar
Date registered: Jan 2011
Vehicle: 2016 C300, 2006 S430, 2003 C240, 1991 190E 2.6
Quoted: 64 Post(s)
Welcome to the forum, izzyyuen
80-100C is normal operating temperature and is within MB spec. And yes, the temp gets lower to about 80C on speeds over 60 mph.
You own a great little Mercedes, btw, what's your location?
izzyyuen likes this.
Do Not Go Where The Path May Lead, Go Instead Where There Is NO Path and Leave a Trail.
Coddger is offline
Old 01-06-2017, 12:06 PM Thread Starter
I am from Hong Kong. Thanks for your information
izzyyuen is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W176 A-Class
