An A160 with a few issues - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-11-2013, 10:05 AM Thread Starter
Date registered: Nov 2013
Vehicle: A160
Long story short, I got an W168 A160 which was ACS but was then fitted with clutch pedal and pump.
All was OK for a short period of time and the all time favorite "F" started coming again. I drove it for some time like this until I got it to a Star equiped friend to clear and re-read the codes after some driving.
So here are the new codes that came up:
ECM - Engine control monolith
P0121-022 M16/6 (Throttle valve actuator) : The signal voltage of component B2/5 (Hot film mass air flow sensor) is implausible in comparison to the value of an actual value potentiometer.
ACS - Automatic clutch system (left most of it so the car can start)
P1747-008CAN fault ( Possible cause : Fault in CAN communication with
P0700-002General system error ( Possible cause : Limit value for adaptation of characteristics )
ESP - Electronic stability program
C1022Fault in CAN communication with control unit N3/5 (ECM control module).
LCP - Lower control panel
B1024 Failure of CAN low at module N72 (Lower control panel control unit)
DCM-RL - Door control module rear left
B1155 Component S21/3 (Left rear power window switch) is operated for more than 25 s or cable has T .
DCM-RR - Door control module rear right
B1155 Component S21/4 (Right rear power window switch) is operated for more than 25 s or cable has T .
RFL - Radio frequency locking/electric central locking
B1101-002Control line for lock switch 2 (lock): PSE , Convenience feature , ATA : T . If no lock switches are fitted, the fault can be ignored.
I'm thinking this time either the throttle valve or the ECU/MAFS is giving me headache, but wanted to as the more advanced than me users here for a hint.
Thank you
Zoner is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W168 A-Class
