Faulty start in the morning (video) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-01-2011, 02:32 AM Thread Starter
Hello, every morning when I start my 1998 w168 the engine starts, then rpm go down and engine stops. I always need to start the engine again and then it will stay on normally. I thought it could be the MAF sensor so I tried to clean it with a spray for carburator cleaning, the situation seemed a little better at first as rpm would go down but engine did not stop and then rpm would go up again.
Check the video I posted. What do you think?
chriz74 is offline
post #2 of 3 (permalink) Old 06-03-2011, 12:27 AM
lofty's Avatar
Date registered: Oct 2004
Vehicle: A160 W168 /2002
If cleaning the mafs helped initially then why not get it checked by ECU testing , mention my site and get a discount of the repair
Have you any codes from The ecu which would help pin point the cause
I take it you have checked air filter condion, and correct positioning and can confirm that the fuel filter has been changed in the last 4 years? 50000.miles
lofty is offline
post #3 of 3 (permalink) Old 06-15-2011, 09:30 AM Thread Starter
update! replacing the tube didn't solve the problem so today I removed the ecu.
I found a broken tube under it!! oil was spread all over.
I modified some of your pictures to show the broken part.
At this point I think this is the problem.
chriz74 is offline
  Mercedes-Benz Forum > Mercedes-Benz Sedan Forums > W168 A-Class
rainy morning in my 560SL video Black560SL R/C107 SL/SLC Class 2 04-03-2011 10:23 PM
Won't Start in Morning. Please Help. glorykid W123 E,CE,D,CD,TD,TE Class 10 09-18-2010 06:27 AM
98 c230-does not want to start this morning Str8 Brabus W202 C-Class 2 08-18-2009 07:40 PM
300E won't start as if battery is faulty JJB236 W124 E,CE,D,TD Class 2 07-18-2006 10:58 AM
cold start in morning CalDeputy R170 SLK-Class 3 05-24-2004 12:10 PM
