in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
Menu
Log in
Register
Home
Forums
Mercedes-Benz Sedan / Coupe / Wagon Forums
W168 A-Class
Follow Forum
Create Post
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
Prev
1
2
3
4
5
Go to page
Go
44
Next
3 of 44
Go to page
Go
Headlamps
kengorrod
Nov 23, 2021
0
529
Nov 23, 2021
by
kengorrod
M
External electricity connection
Mercy Mercy Mercy
Nov 21, 2021
1
670
Nov 21, 2021
by
MB•David
K
Turn Signal Problem, selecting opposite way
Kid Nothing
Aug 5, 2010
2
20
30K
Nov 20, 2021
by
neilmac
A140 W168 service manual
mariussv
Nov 12, 2021
0
899
Nov 12, 2021
by
mariussv
2004 A160 Limp mode
JethrowCatch
Nov 8, 2021
1
1K
Nov 8, 2021
by
MB•David
ECU swap Mercedes A Class w168 A160 (2001)
ricc
Nov 8, 2021
2
1K
Nov 8, 2021
by
MB•David
J
P1843 trans fault and weak/gone 1st gear fix approach
JackT99
Oct 29, 2021
0
787
Oct 29, 2021
by
JackT99
Mercedes-Benz w168 a160 double din
Colin2385
Oct 26, 2021
4
2K
Oct 28, 2021
by
MB•David
w168 170 cdi cold weathers
recepyolcu
Jan 14, 2021
4
1K
Oct 24, 2021
by
Nikos Laf
Jump Starter Cable / Booster Cables Contact Location ?
MK MBZ
Oct 6, 2021
0
716
Oct 6, 2021
by
MK MBZ
W168 a160 ecu wiring diagram
My garage
Dec 28, 2019
4
4K
Oct 4, 2021
by
Santiago160awb
D
Exterior door handles
Dangermouse67
Sep 27, 2021
0
634
Sep 27, 2021
by
Dangermouse67
G
Radio Code A160 year 2000
Gulam Ghous Mahomed
Jan 15, 2020
3
2K
Sep 22, 2021
by
DenA160
K
New Scanner, many errors. Help
kraizeg
Sep 18, 2021
0
683
Sep 18, 2021
by
kraizeg
A140 cutting down on reverse, P0335 error
Pero12
Sep 12, 2021
0
687
Sep 12, 2021
by
Pero12
I
A160 Elegance engine start delay...need help to identify the problem!
ionab
Mar 12, 2013
1
2K
Aug 31, 2021
by
Long.H
A
semi automatic problem (no clutch)
Ali_c
Jul 16, 2007
3
4
5
88
99K
Aug 19, 2021
by
bAhAcAn
D
W168 Trim/parts swap
Dangermouse67
Jul 29, 2021
13
2K
Aug 16, 2021
by
Dangermouse67
D
Oil level warning sensor
Dangermouse67
Jul 30, 2021
0
780
Jul 30, 2021
by
Dangermouse67
C
A160 NO START
churchy
Oct 1, 2014
3
10K
Jul 29, 2021
by
noumea50
T
Turn signal fault / instrument cluster fault
the repair guy
Sep 8, 2017
4
5K
Jul 25, 2021
by
Andrew Fredericks
Draining battery
Pongo Kiwe
Jul 18, 2021
0
923
Jul 18, 2021
by
Pongo Kiwe
Q
New Alternator not charging
qvanzyl
Sep 27, 2018
2
3K
Jul 4, 2021
by
Path57
J
How to bleed air out of ACS clutch?
jeev80
Nov 6, 2009
6
14K
Jun 20, 2021
by
jninmps
A
interior lights stay on A Class
a210lovely
Jun 14, 2006
5
20K
Jun 16, 2021
by
Rabia Jacobs
L
Do cheap OBDII work with w168?
laEstrella
May 29, 2021
4
3K
Jun 10, 2021
by
DrX
L
What are the symptoms of bad oxygen sensor?
laEstrella
May 29, 2021
2
1K
May 29, 2021
by
laEstrella
A170 Automatic Gearbox Oil Change
DiartM
May 4, 2021
3
5K
May 28, 2021
by
forrera
A160 idle low
Sabrinapanda
Apr 14, 2021
3
900
May 28, 2021
by
forrera
L
A140 losing power at high speed
laEstrella
May 28, 2021
0
797
May 28, 2021
by
laEstrella
Z
Considering an A class, is it worth it?
ZhakirSetie
May 25, 2021
1
793
May 27, 2021
by
SL BRABUS
W168 1997 Trun Signal & flasher stopped working
gilius
May 20, 2021
0
781
May 20, 2021
by
gilius
S
Coolant fan constantly running
stevie200685
Feb 18, 2019
4
3K
May 10, 2021
by
DrX
J
Fuse #1 keeps blowing
Joso123
Feb 19, 2021
2
1K
May 4, 2021
by
ianrandom
R
Power Steering Pump 1684660101 disassemble
RVM
Aug 14, 2020
2
2K
Apr 28, 2021
by
Martin Font
Prev
1
2
3
4
5
Go to page
Go
44
Next
3 of 44
Go to page
Go
Join the discussion
Continue with Facebook
Continue with Google
or
sign up with email
W168 A-Class
1997-2004 : A140, A160, A160 CDI, A170 CDI, A190
Moderators -
forrera
SL-BRABUS
Show more
6.1K
posts
7.5M
views
Join Community
Grow Your Business
Forum Staff
View All
forrera
SL BRABUS
Top Contributors this Month
View All
Jas 7
FlameGrilledBob
mwtc.mike
Recommended Communities
AVS Forum
1M+ members
Bimmerfest BMW
739K+ members
Mercedes EQ Forum
2K+ members
Join now to ask and comment!
or
sign up with email
Home
Forums
