M276 Valve cover removal - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-26-2019, 12:57 PM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 6 Post(s)
I need to check the cam timing on my 2014 ML350 M276 engine right (passenger) side.
Removing the valve cover is getting problematic.
The current show stopper is the bracket on the rear of the head.
One retaining screw is accessable. Is there a way to remove the other(s)?
I need to remove the valve cover to ensure proper cam timing after I rotated the crank with the cam chain tensioner removed.
Thanks or your time,
Alex
Halexb is offline
post #2 of 5 (permalink) Old 07-27-2019, 05:29 PM Thread Starter
Quoted: 6 Post(s)
Took a bit, some expert advise , but I got it.
Halexb is offline
post #3 of 5 (permalink) Old 07-27-2019, 06:17 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 917 Post(s)
Alex
So, what did you find?
Witek_M is offline
post #4 of 5 (permalink) Old 07-27-2019, 07:18 PM Thread Starter
Quoted: 6 Post(s)
And the beat goes on
Looked like the intake was off by 2 teeth. I removed the tensioner and eased the chain over 2.
I checked the cams at first with a gauge a friend lent me. The intake didn't fit.
After moving the intake 2 teeth, the gauge fits on both cams.
I think the crank is at #1 TDC (see pic).
I don't see any laser marks, lines, etching, on the cams to indicate proper setting.
What do ya think?
ID:	2530922   Click image for larger version
Name:	Intake sans gauge.JPG
ID:	2530924   Click image for larger version
Name:	Intake with gauge.JPG
ID:	2530926   Click image for larger version
Name:	Exh With gauge.JPG
ID:	2530928   Click image for larger version
Halexb is offline
post #5 of 5 (permalink) Old 07-27-2019, 10:15 PM Thread Starter
Quoted: 6 Post(s)
Well now that the sun has died down a bit (doing this job in my driveway), I am seeing some marks.
Do these marks indicate the exhaust cam is off? With the crank set at TDC #1 I believe.
Name:	Intake close up marks.JPG
ID:	2530966   Click image for larger version
Name:	Exh marks close up.JPG
ID:	2530968   Click image for larger version
Halexb is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
