W166 M276 R. Cam Timing - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-23-2019, 06:19 PM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 6 Post(s)
I am completing the right timing chain tensioner replacement on my 2014 ML350. I would like to ensure that the chain hasn't jumped a tooth.
Can anyone tell me if the cam position in the pictures is correct?
Crank set to 40 when viewed from directly above.
I have a tool to check the cams from under the valve covers but I sure would prefer to avoid removing the valve cover.
Thanks for your time,
Alex
Name:	R Cams 40 degrees.JPG
ID:	2530174   Click image for larger version
Name:	R cams TDC 40 Degrees.JPG
Halexb is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
