Help-LED emblem wiring to headlights - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-25-2019, 07:44 AM Thread Starter
Date registered: Jun 2016
Hi all,
i'm trying to wire a LED star emblem to the headlights so that its not on all the time. The problem is, I can't find the wiring for the headlights. Any help would be appreciated.
2016 GLE 350
cadman33619 is offline
post #2 of 7 (permalink) Old 06-25-2019, 12:50 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 807 Post(s)
Originally Posted by cadman33619 View Post
Hi all,
2016 GLE 350
You need to be a bit carful tapping into headlight wiring especially if you have LED headlights. Current is monitored in all your lighting to detect a faulty light. Not that that happens much with LEDís. Where do they suggest to hook it up to?
Just check the voltage with a multi meter before you connect it up.
mattml430 is offline
post #3 of 7 (permalink) Old 06-27-2019, 10:10 AM Thread Starter
actually they dont suggest at all. i dont have LED headlights... just the stock bulbs. I was hoping to connect it so that it only comes on when the headlights go on.... instead of having it on all the time.
Can you suggest a way to do that?
if thats not possible then i'll go ahead and connect it to the fuse box and let it be on all the time.
...although i dont know which fuse i should use.
post #4 of 7 (permalink) Old 06-27-2019, 10:48 AM Thread Starter
does anyone have a diagram for the under-hood fuse box? not even the owner's manual has something showing what each fuse is for.
post #5 of 7 (permalink) Old 06-27-2019, 12:40 PM
mattml430's Avatar
Quoted: 807 Post(s)
You should be ok to come off the headlights with halogen bulbs.
post #6 of 7 (permalink) Old 06-28-2019, 07:12 AM Thread Starter
i see the two wires connected to the bulb itself... but they appear to be the same color. how will i know which is power? the LED emblem has red (power) and brown (ground)... which will go to chassis.
post #7 of 7 (permalink) Old 06-28-2019, 01:34 PM
mattml430's Avatar
Quoted: 807 Post(s)
Brown is your ground. Donít hook it directly to the bulb find your circuit for the parkers and hook it to that. If your that unsure about wiring things up your best to take it to an auto electrician. You need a multi meter to check for + positive power.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
