Driver's side carpet wet - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-26-2019, 08:20 AM Thread Starter
Date registered: Sep 2010
Vehicle: 2015 ML 350 Bluetec
Quoted: 2 Post(s)
Question Driver's side carpet wet
Hi, I have a 2015 ML350 Bluetec and I was vacuuming the front drivers side and the carpet is wet. We had a heavy rain last night.
Has anyone got any ideas where the water might have come from??
Thanks,
danrob is offline
post #2 of 6 (permalink) Old 05-26-2019, 12:41 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 791 Post(s)
Thanks,
The first place to check would be the sunroof drains.
mattml430 is offline
post #3 of 6 (permalink) Old 05-31-2019, 06:51 AM
Date registered: May 2019
Vehicle: Lookout for W166 ML63
Check and make sure all drain holes are cleared free for the water to travel from the engine bay and the sunroof tracks.
Get this done quick otherwise you might develop electrical gremlins!!
Sunny-AMG is offline
post #4 of 6 (permalink) Old 05-31-2019, 07:24 PM Thread Starter
Quoted: 2 Post(s)
Thank you for your information. I was planning on using a flexible wire. Would you have any other suggestions for clearing the drain holes. I am assuming I will need to clear the entire path.
Thank you,
danrob is offline
post #5 of 6 (permalink) Old 05-31-2019, 07:26 PM
mattml430's Avatar
Quoted: 791 Post(s)
Thank you,
Wet vacuum is good from the top.
post #6 of 6 (permalink) Old 06-03-2019, 03:47 AM
Hey,
Check the reed valve as well, usually Mercedes keeps a uniform location for this. If its obstructed, this will leak into the foot-well of the ML.
Flexible wire is good as well but be extremely caution when doing this. Do your research first then plan your works.
Hope it all works out friend!
Check out................
You are being redirected...
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
