How to Adjust Sunroof in ML350? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 05-17-2019, 11:19 AM Thread Starter
Date registered: May 2018
Vehicle: 2004 E320 Wagon RWD
Hey Folks,
I've searched this topic repeatedly. To date, I've only ever found scant instructions for adjusting sunroofs of other models, from which I am unable to extrapolate a solution.
I am experiencing loud wind noise at 40+mph with the sliding/tilting sunroof (code 414) fully closed. By manually pressing upward on the leading edge (1-2mm) the sound level approaches what I would deem to be normal. (I have yet to determine its relative position to the leading edge while pressed upward; however, it is only ~1mm below the roof level at rest.) Releasing it returns it to its previous orientation and the accompanying noise level. All seals are in great shape, and the contact areas are clean and free of debris. The sunroof panel operates normally with no impedance.
Does anyone have instructions for adjusting the height of the standard sunroof?
Thanks,
Michael T
mijotu is offline
post #2 of 2 (permalink) Old 05-17-2019, 10:35 PM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 228 Post(s)
Year of your ML? Your profile says you have an E wagon, and that is all.
Sent from my BlackBerry Key2 using Tapatalk
WE47B1ME is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
DIY Replace Sunroof Gear | 1984 W123 300D Wamp W123 E,CE,D,CD,TD,TE Class 15 11-17-2018 06:30 AM
sunroof question - w124 vs w202? rama1200 W124 E,CE,D,TD Class 3 04-24-2016 09:42 AM
Sunroof rattle issue. The back of the sunroof bavenda W163 M-Class 10 04-22-2014 03:31 PM
New Sunroof Info... cooljjay W123 E,CE,D,CD,TD,TE Class 1 05-07-2012 12:19 AM
sunroof doesn't work anymore/ 2004 ML350 Mattsml W163 M-Class 3 04-17-2012 08:10 AM
