WIS for R&R L&R Cam Chain Tensioners? - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 05-15-2019, 09:20 AM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 5 Post(s)
My new (to me) ML350 (M276 engine) is making noises like it needs the cam chain tensioner check valve install bulletin performed. I checked the engine # and it appears that the engine already has the check valves installed.
I've seen Utube videos of the right tensioner and check valve install but there isn't enough info on the video.
Does anyone have the Merc. WIS for the check valve install and associated timing chain tensioner(s) replacement?
Gunna have some fun...
Alex
Halexb is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
OM606/5/4 Timing Chain Replacement How-to & Pictorial frans-c W210 E-Class 0 08-10-2015 01:50 PM
Mercedes WIS ASRA 1 / 2011 wisprovider General Mercedes-Benz 9 02-19-2012 04:05 PM
New Cam Chain Tensioner, etc. XXTi R/C107 SL/SLC Class 8 08-08-2011 11:28 AM
Timing chain and tensioners JMK616 W126 S,SE,SEC,SEL,SD,SDL Class 17 02-02-2011 06:02 PM
"Mr. Timing Chain Duplex" New Patient for you hsahai W126 S,SE,SEC,SEL,SD,SDL Class 8 06-05-2010 10:19 AM
