2014 ML350 Engine Number Location - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-08-2019, 05:15 PM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 5 Post(s)
I am considering doing the timing chain tensioner oil check valve installations and need to locate the engine number on my ML350.
Where is it located? It sure isn't obvious.
Thanks for any help,
Alex
Halexb is offline
post #2 of 5 (permalink) Old 05-08-2019, 10:10 PM
Date registered: Mar 2019
Vehicle: 2003 ml500
Quoted: 27 Post(s)
Not sure but wonder if a vin decoder will give you it?
wallyo is offline
post #3 of 5 (permalink) Old 05-08-2019, 10:18 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 735 Post(s)
Believe it is on top of right motor mount bracket. You likely will have a very hard time seeing it, it's right above the right half shaft and the motor mount itself is blocking it, along with the starter.
EPC and vin decoder might give you the serial number. I have a spare M276 engine in my shop, I can look at it tomorrow.
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is offline
post #4 of 5 (permalink) Old 05-09-2019, 08:43 AM Thread Starter
Quoted: 5 Post(s)
I haven't seen a Vin decoder before. It worked!
https://www.vindecoderz.com/
Most excellent. Thanks much.
And now step to # 900....
Alex
Halexb is offline
post #5 of 5 (permalink) Old 05-10-2019, 10:49 AM
Vehicle: 2003 ml500
Quoted: 27 Post(s)
Alex
Glad it gave you the info! it is pretty cool and in a way scary that that much info on you car can be found just with a vin number.
wallyo is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
E 320,straight 6, versus V6 engine Viriato W210 E-Class 24 03-04-2018 06:19 PM
Engine Light and Shaking ML350 2014 Assel Detailing and Car Care 0 02-28-2018 01:02 AM
Injection Pump fuel adjustment for the MW and M pumps, engine tuning and maintenance Forcedinduction W123 E,CE,D,CD,TD,TE Class 5 11-28-2017 01:19 AM
300d engine number location tinbum W124 E,CE,D,TD Class 0 01-19-2008 05:34 PM
320 CDI vs 350 rubensans W164 M-Class 1 05-03-2005 03:36 PM
