New Owner... Some Issues - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-25-2019, 05:06 PM Thread Starter
manninp's Avatar
Date registered: Apr 2019
Quoted: 4 Post(s)
Hey folks! I have a new to me 2012 ML350 Bluetec, and I have made an appt with the dealer to have the following looked at. Any insight in advance for my inquiring mind?
- Parking Sensors - Only Beep and have red light then turn off (no dash errors)
- Rearview Camera - super grainy, can't see anything
- Sunroof button - not there
- Sport/Comfort Mode - stuck in sport mode (no dash errors)
- Passenger power headrest - clicking relay sound when press button, headrest does not move
- Check Rear taillight warning on dash
- Blind Spot Inoperative - have had this message twice but then works fine need after a restart
- Fuel Mileage reading - after 950km car said 7.5L/100km but actual usage was 9.3
- Reset A Maintenance Reminder - Will dealer reset this? Service was done at a Honda store where I bought it last week
- Best way to update NAV without paying $300+?
Thanks very much for any insight in advance!
manninp is offline
post #2 of 7 (permalink) Old 04-26-2019, 03:15 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 791 Post(s)
Mine only beep for a short time then turn off. Itís better than them constantly going off.
Have you cleaned the lens of the camera or check it hasnít been all scratched. It may need polishing.
Sunroof button! Is it gone or your not sure where it is?
Quite possibly some fluid has been spilled into the button and buggered it. Might need replacing or pulling apart and cleaning with electrical contact cleaner.
Give the headrest a bit of a push while operating it up or down. See if that helps.
Replace the bulbs, the bottom contact can become a bit dodgy and cause faults. Change them both to new ones.
Not sure about your blind spot inoperative.
Average mileage could be different depending on when it was last reset. Did you check it from last start menu or the from last reset menu.
Jump on YouTube and youíll see a couple of good videos on the procedure to reset the service message.
mattml430 is offline
post #3 of 7 (permalink) Old 04-26-2019, 04:23 AM Thread Starter
manninp's Avatar
Quoted: 4 Post(s)
Originally Posted by mattml430 View Post
Mine only beep for a short time then turn off. It’s better than them constantly going off.
Have you cleaned the lens of the camera or check it hasn’t been all scratched. It may need polishing.
Jump on YouTube and you’ll see a couple of good videos on the procedure to reset the service message.
Parking sensors aren't working. I mean the red light comes on and beeps for no reason then shuts off but they aren't actually operational
I've cleaned the lense but it's possibly quite scratch. How does one go about polishing that little lense?
Plastic square sunroof button is missing
I checked mileage from last reset, and I am the one that reset when I had last filled up
Thanks for your help!
manninp is offline
post #4 of 7 (permalink) Old 04-26-2019, 12:32 PM
mattml430's Avatar
Quoted: 791 Post(s)
If you get a pro level scanner and go into park assist live data it will tell you which sensor is not working. Had a similar problem in a C Class. Was a bad sensor.
Sounds like itís had a bit of a rough start in life.
Use some good quality cream polish and soft cloth to polish the camera lens.
post #5 of 7 (permalink) Old 04-26-2019, 02:05 PM Thread Starter
manninp's Avatar
Quoted: 4 Post(s)
Sounds like it’s had a bit of a rough start in life.
Taking it to the dealer on Tuesday so will find out what all these issues are all about then. I'll see if I can attempt a bit of polishing on the lense. It does look pretty scratched up
manninp is offline
post #6 of 7 (permalink) Old 04-26-2019, 08:50 PM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 226 Post(s)
Sounds like it was beat to death. Don't know how one loses their sunroof button. As Matt, said, you need to get a pro scanner to point you in the right direction, otherwise, look forward to a $2000+ plus bill from the dealer for these issues if you choose for them to fix them. Maybe don't buy a Mercedes from a Honda dealer in the future
Sent from my BlackBerry Key2 using Tapatalk
WE47B1ME is offline
post #7 of 7 (permalink) Old 04-30-2019, 03:32 PM Thread Starter
manninp's Avatar
Quoted: 4 Post(s)
Update on my issues:
- Parking sensors were not connected (front bumper was repaired, some idiot didn't reconnect the wires). Now working, $70
- Passenger power headrest - fixed with software update, $140
- Rearview Camera - needs to be replaced due to cracked lense, $850
- Sunroof button ($40 eBay)
- Sport/Comfort Mode - right rear shock/dampening valve unit malfunction, $1000
- Right Tail Lamp warning - outer lamp needs to be replaced, quote to come
- Blind Spot Assist Inoperative - replace right mirror glass, corroded wires, quote to come
- Washer Fluid Leaking - need to replace hose, quote to come
- MVI (Motor Vehicle Inspection) - failed due to tie rod end. Also had to have front tint removed and needs a brake backing plate. Quote to come
Selling dealer not going to be happy when I tell them over $3000 due to their neglect
manninp is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
New 2005 W211 CDI Owner & Issues: Repair Thread evan717 W211 E-Class 30 03-18-2019 07:39 AM
New s600 owner ! Some issues I need help with tusabes W220 S-Class 1 12-30-2016 05:23 AM
New owner with a few issues Uksoundz W168 A-Class 0 03-29-2014 07:22 AM
Proud new owner of a 2008 e350. I have several issues. The Thomas J W211 E-Class 4 06-10-2013 12:03 AM
E55 in Tectite Gray xman W210 E50 AMG, E55 AMG 11 08-18-2006 02:44 PM
