2014 ML 350 BlueTec Pre Safe Functions Limited - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 02-03-2019, 04:54 PM Thread Starter
Date registered: Feb 2019
Quoted: 6 Post(s)
I got the sign saying Pre Safe Functions Limited on the dashboard, I did wash my car and all the sensors but the sign didn’t go away, did anyone else had the same problem and If yes how did you fix It, thank you!
gramen is offline
post #2 of 11 (permalink) Old 02-03-2019, 10:01 PM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 227 Post(s)
Originally Posted by gramen View Post
I got the sign saying Pre Safe Functions Limited on the dashboard, I did wash my car and all the sensors but the sign didnít go away, did anyone else had the same problem and If yes how did you fix It, thank you!
You need to scan the truck and see what comes back. Did you high pressure it? Could have dislodged a sensor wire.
Sent from my BlackBerry Key2 using Tapatalk
WE47B1ME is online now
post #3 of 11 (permalink) Old 02-04-2019, 12:36 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 795 Post(s)
Scanning it may help point you in the rite direction to finding a plug that is full of water. You might have to pull a view apart and let them dry out and then spray some CRC electrical contact cleaner in them. It evaporates and leaves them clean and dry.
mattml430 is offline
post #4 of 11 (permalink) Old 02-04-2019, 12:22 PM Thread Starter
Quoted: 6 Post(s)
It was a rainy day and I drove into a big hole with water so after that the sign came on, so maybe sensor wires are wet but I’ll scan and see what It says, my mechanic didn’t seem interested helping me out he just said that doesn’t know anything about that
gramen is offline
post #5 of 11 (permalink) Old 02-04-2019, 05:23 PM
WE47B1ME's Avatar
Quoted: 227 Post(s)
It was a rainy day and I drove into a big hole with water so after that the sign came on, so maybe sensor wires are wet but Iíll scan and see what It says, my mechanic didnít seem interested helping me out he just said that doesnít know anything about that
First you said you washed your car, now you're saying you drove into a big puddle? And you already took to a mechanic but they didn't want to charge you for "diagnosing"? I don't know if this testimony would hold up in court
post #6 of 11 (permalink) Old 02-04-2019, 06:42 PM Thread Starter
Quoted: 6 Post(s)
I said I did wash my car and all the sensors before someone tells me “ take all the dirt from the sensors” I did everything possible what I saw online, but the problem occurred when I drove into the puddle which I didn’t want to believe that a $70K car would give me that trouble just because I drove on a water puddle.
gramen is offline
post #7 of 11 (permalink) Old 02-04-2019, 08:56 PM
WE47B1ME's Avatar
Quoted: 227 Post(s)
I said I did wash my car and all the sensors before someone tells me ď take all the dirt from the sensorsĒ I did everything possible what I saw online, but the problem occurred when I drove into the puddle which I didnít want to believe that a $70K car would give me that trouble just because I drove on a water puddle.
Your verbiage was confusing in your first post, sorry. You never said you drove thru a puddle at first. From reading it, I assumed you were saying "I washed my car and the sensors stopped working and the message illuminated."
Regardless, you still need to have the truck scanned with a pro level scanner. It will tell you exactly what's wrong or point you in the right direction. It's a guessing game here until you do so.
mattml430 likes this.
post #8 of 11 (permalink) Old 02-04-2019, 08:57 PM
mattml430's Avatar
Quoted: 795 Post(s)
Owning any late model car these days itís definitely worth investing in a decent pro level scanner. If your a bit handy it will pay for itself in no time.
post #9 of 11 (permalink) Old 02-04-2019, 09:29 PM Thread Starter
Quoted: 6 Post(s)
Suggest me one scanner?
gramen is offline
post #10 of 11 (permalink) Old 02-05-2019, 02:28 AM
mattml430's Avatar
Quoted: 795 Post(s)
I have the Foxwell NT630 that I used on my old ML w163 and it was great for that. It worked ok on the 166 but didnít really get into all the systems to well.
I invested in a snap on scanner which is probably a little over the top for the home mechanic but I have a 2013 & 2015 Benz and want to service and look after them myself. I have a view friends that seem to bring all the car issues my way as well so it will pay for itself. Iíd like someone else to advise on what they use on the 166 just to point you in the rite direction.
The Snap On is brilliant and gives you very detailed help on a lot of problems.
The Autel Maxidiag has been a highly recommended scanner as well. Spending a view hundred on a scanner will pay for itself in the first few uses. Steer clear of generic OBDll scanners they wonít get into the systems you need to.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W166 M-Class / GLE-Class
Considering 2014 E 350 CPO as 3rd car NC211 W212 E-Class 8 06-25-2017 04:11 PM
2014 Chevrolet Sonic Gets Deep Magenta Metallic Limited Edition Color AutoGuide.com AutoGuide.Com News 0 07-22-2013 01:50 PM
2014 Chevrolet Corvette Limited to High-Volume Dealers AutoGuide.com AutoGuide.Com News 0 01-23-2013 09:50 AM
Not intended for another oil war. JeffreyP W210 E-Class 22 01-19-2010 01:17 PM
Limited Slip Differential on SLK 350 - Anyone Interested? Cixi R171 SLK-Class 2 04-27-2009 03:37 PM
