Hi,
Currently I have below code and I was wondering what will be the base way to fix this issue without guessing and keep replacing until it fixes the problem:
P0300
P0301
P0302
P0303
P0306
Before above code, I had code P0305 and I replaced new Spark Plug and it fixed problem but now I got above codes. I have replaced all 6 original MB Spark Plug on Jan 2 2019, not too long ago. Could that be bad spark plug ? I bought them from eBay.
I am thinking of doing below but it seems lengthy process which I am trying to avoid if possible.
1) Replace spark plug on Cylinder 1, 2, 3, and 6 and drive the car and see which one got fixed.
2) Replaced Coil for Cylinder for above cylinder where code is still not fixed.
Is there anyway I can check whether fix worked or not without driving ?. Because I want to avoid keep opening and closing Engine cover. I do have Bluetooth OBD2 Adapter and i use TORQUE phone app to read and clear codes.
Any other idea ?
Thanks in Advance.
P0300
P0301
P0302
P0303
P0306
Any other idea ?
Thanks in Advance.
