Fuel Gauge, Indicators, and Rear Trunk release all broke - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-17-2019, 05:23 PM Thread Starter
Al1
Date registered: Oct 2010
Vehicle: 2006 ML320
At the weekend, suddenly all of these things stopped working on my 2006 ML320 (UK).
The rear trunk release handle does nothing at all, but the lock button (keyless) still works. Also, the motor which pulls the trunk closed when you don't slam it hard is also doing nothing.
The indicators do nothing, but the hazards still go.
The fuel gauge reads zero.
I can't believe that 3 separate faults all happened at once. Is there something common to these three things? Rear SAM was replaced a few months ago due to leaking rear light cluster. Rear light cluster seal was done at the same time, and there's no obvious evidence of water ingress today.
I am hopelessly useless at anything mechanical, but if there's a fuse or something I can check I can just about cope with that.
Many thanks for any pointers.
Al1 is offline
post #2 of 7 (permalink) Old 06-17-2019, 07:44 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1543 Post(s)
Who replaced the rear SAM?
Where did you get the replacement SAM?
43sqd is offline
post #3 of 7 (permalink) Old 06-17-2019, 11:20 PM Thread Starter
Al1
Vehicle: 2006 ML320
Local, non-dealer Merc specialist.
Al1 is offline
post #4 of 7 (permalink) Old 06-18-2019, 03:57 PM
Was it used, new? Did he give you back the old one?
43sqd is offline
post #5 of 7 (permalink) Old 06-18-2019, 04:19 PM Thread Starter
Al1
Vehicle: 2006 ML320
Pretty sure it was new, and yes I still have the old, very corroded one.
I've concluded, through everything I'm able to find on these forums, that the only thing that's in common with everything that's gone wrong (Which, incidentally, includes brake lights I've discovered), is the rear SAM. In a way, I hope it is because then it should be repaired under warranty.
Al1 is offline
post #6 of 7 (permalink) Old 06-20-2019, 04:50 AM
All of your problems are controlled by the rear SAM. You, yourself must know what the code numbers are. If you rely on a mech. telling you the truth as to what the problem is, you will be in the dark.
You must get your own scanner and read the codes in every module in your car and then return to the mech. who in stalled the SAM and then see what he reveals as to what the problem is. But do not tell him that you have already scanned for codes.
https://www.amazon.com/Autel-MD802-M...autel+maxidiag
43sqd is offline
post #7 of 7 (permalink) Old 06-24-2019, 11:47 AM Thread Starter
Al1
Vehicle: 2006 ML320
Update on this:
Took it to Merc main dealer, who agreed to replace the SAM under warranty (2 yr warranty on the new part)
Thanks for your help though!
Al1 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
