236.14 vs 236.15 ATF for my 2011 550ML? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-09-2019, 05:09 PM Thread Starter
alpac's Avatar
Date registered: Aug 2013
Vehicle: 1992 500SL, 1999 CLK 320 conv, 2015 ML350, (2011 ML550 gone, C320 wagon gone, 2005 C240 gone)
Quoted: 91 Post(s)
I will soon be replacing the ATF in my 2011 550ML but I am confused about which ATF I should use. Is it the 236.14 (red) or 236.15 (blue) specs? I am reading that for the 722.9 MB transmission they changed from 236.14 to 236.15 in 2010 so logically mine should take 236.15 but I am not sure. The ATF was replaced 2 and 1/2 years ago by a mercedes independent mechanic. I put only 40k miles on the ML since but I am experiencing a slight shuddering when the car is hot and around 1500 RPM when accelerating slowly and I guess when it is in 3rd or 4th gear. This is only when the car is hot and mostly in weather temp above 80 so I am thinking when the ATF looses its viscosity because of the temperature. The problem occurred about a 1000 miles after the ATF was replaced. I know that the 236.15 spec has a lower viscosity index than the 236.14 so I am wondering if they put the wrong fluid the last time the ATF was replaced. Any input will be greatly appreciated.
Thanks
alpac is offline
post #2 of 5 (permalink) Old 06-09-2019, 05:18 PM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 193 Post(s)
Your car should take the blue fluid.
james.calton1 is offline
post #3 of 5 (permalink) Old 06-09-2019, 05:27 PM Thread Starter
alpac's Avatar
Quoted: 91 Post(s)
Thanks for the quick response James but I am still not sure. Looking at the carfax my ML was first put for sale at the end of July 2010. I just found an article (see below) indicating that the new 722.9 transmission that takes the new fluid was implemented in the fall of 2010 so after mine was built and put for sale.
Here is the article https://www.europeantransmissions.co...edes-trani.PDF
alpac is offline
post #4 of 5 (permalink) Old 06-09-2019, 05:30 PM
Quoted: 193 Post(s)
Production would have been switched over just past mid year 2010. Your dealer should be able to tell you for sure using your VIN.
post #5 of 5 (permalink) Old 06-09-2019, 06:42 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
The easiest way to tell is if the car has the "auto stop" or "start/stop" feature where the engine automatically shuts off when idling, such as at a traffic light, then restarts when you remove your foot from the brake pedal. If your car has this feature, then you MUST use the blue 236.15 fluid. If not, use the 236.14 red fluid.
- RODNEY
My Stable:
rudeney is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
