Rear SAM, "input to Circuit 54, short to positive"? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-22-2019, 02:53 PM Thread Starter
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
I've got a 2008 ML320 CDI I'm troubleshooting here. The brake lights are staying on all the time when the engine is running, no matter what gear I'm in or weather I'm driving or not. The right turn signal was occasionally flickering rapidly as though a bulb was out too, but they are all tested in good working order. And as I got home, the headlights started flashing as if the alarm was triggered (no siren.)
Scanning all the control modules, the only relevant code showing up, is code 909A in the rear SAM, "the input to circuit 54 has short circuit to positive." It is current and stored.
Any idea what could be causing this? I'm fearing a malfunctioning Rear SAM, I see no signs of
obvious water intrusion .
_______________________________________
"Concentrated power is not rendered harmless by the good intentions of those who create it."
2005 CLK320 - Wifes DD
2005 E320 CDI - Black on Black 450K+miles - MY current DD
2006 E320 CDI - Dads DD
2007 E320 Bluetec - Sisters DD
2008 ML320 CDI - Mothers DD
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Rossafuss is offline
post #2 of 6 (permalink) Old 05-22-2019, 04:20 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 888 Post(s)
I know you are using DAS. Click on the code then Test. It should take you to test program for that code.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 6 (permalink) Old 05-23-2019, 04:51 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1549 Post(s)
You have to go the extra yard and remove everything in the spare tire area including the gray mat to check for water intrusion and inspect the rear SAM which sits on the floor.
Witek_M likes this.
43sqd is offline
post #4 of 6 (permalink) Old 05-23-2019, 05:55 AM Thread Starter
Rossafuss's Avatar
Quoted: 195 Post(s)
Typically circuit boards dont short to POSITIVE, so due to the water intrusion problem these vehicles are known for near the rear sam, my thought was that water on the circuit board is causing the short between circuits.
So i took the rear SAM out last night to inspect for water, and sure enough, the rear SAM was WET, water all around sitting in the bottom of that well. i removed the board, cleaned the whole thing with electrical parts cleaner and a soft bristle brush, and dried it at 120f in the oven. cleaned the whole area out where the SAM sits, and put everything back together. Problem solved! No DTC's in the rear sam anymore. There was what looked like corrosion all over the board, but given how easily it cleaned off, i think it was actually mineral scale left behind from water intrusion. the board cleaned up very nicely.
trying to find where the water was getting in, im completely stumped. the tail light seal when removed was forming a perfect seal, and the sealing surface was dry and spotless. there WAS however water INSIDE the right side tail light. no visible signs of cracks or broken seals on the tail light housing, so i'm not quite sure where the water is coming in.
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
post #5 of 6 (permalink) Old 05-23-2019, 06:01 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 888 Post(s)
Sounds like it's time for new tail light and seal of course.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 6 (permalink) Old 05-23-2019, 10:17 AM
Get the seals as soon a possible or else the next time it rains you will have new problems.
This time attach the seals to the body opening and not on the tail lamp.
Name:	Tail Lamp Seals Part Numbers.jpg
43sqd is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
