2008 ML320 CDI Towing - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-16-2019, 07:34 AM Thread Starter
Date registered: May 2019
I have a ML320 CDI with air suspension and I cannot find any towing information with this configuration, I know my gross is 7200# but what is the hitch weight limits
Ctrapani is offline
post #2 of 5 (permalink) Old 05-16-2019, 09:05 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 789 Post(s)
Send a message via Skype™ to art_arev
art_arev is offline
post #3 of 5 (permalink) Old 05-21-2019, 04:02 PM
PSDCamperVan's Avatar
Date registered: Jul 2015
Vehicle: 2005 E320 CDI (SOLD); 2008 ML320 CDI 4MATIC
Quoted: 35 Post(s)
I've read somewhere that 300 to 350# tongue weight is preferred MAX for ML.
PSDCamperVan is offline
post #4 of 5 (permalink) Old 05-23-2019, 06:13 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
That engine is more than capable of whatever the chassis is able to tow. Max tow weight is rated at 3500 kg (7700 lbs) WITH trailer brakes and a quality brake controller. The W164 CDi is quite heavy with a gross weight (with fuel and passengers/cargo) of 6200lbs, and only 400lbs lighter than its bigger cousin, the GL. so really, in order to tow safely, the only thing you need to get under control is tongue weight and sway. With a decent weight equalizer system and sway bar(s), i Don't doubt the ML CDI could easily and comfortably tow just shy of 8k lbs.
Rossafuss is offline
post #5 of 5 (permalink) Old 05-24-2019, 07:02 PM
Quoted: 35 Post(s)
I'd guess ML chassis is similarly constructed to sprinter but not sure... ML is 4matic so there's that especially helpful when hauling out on a algae-covered boatramp @lowtide.
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Buying advice- 2008 ML320 CDI David Frank W164 M-Class 13 06-06-2018 09:38 PM
MTEC H7 4500K HID Installed on 2008 ML320 CDI Yazovets! W164 M-Class 63 04-30-2018 12:50 PM
2008 ML320 cdi Active headlights!!! igorl W164 M-Class 2 03-15-2016 07:49 AM
2008 ML320 CDI - questions mike62 W164 M-Class 3 10-04-2015 06:44 PM
2008 ML320 CDI Which engine oil? geebra W164 M-Class 9 06-25-2013 05:33 PM
