ML63 Alignment woes... - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-11-2019, 11:52 PM Thread Starter
Date registered: Mar 2019
Vehicle: 2007 ML63
So... I can't seem to get my ML63 going in a straight line all the time... I had the alignment done when I first got the car after it had new front bushes, track rod ends and drop inks etc, still pulled to the right slightly and still had to correct it with the steering wheel slightly towards 11... I assumed it was the tyres, being that although all the same brand and tread, they all seemed to be at different wear heights... So I got 4 new tyres, had the alignment checked again, this is 4 wheel laser alignment on the the Hunter Hoawkeye each time, and although slightly improved and sometimes it will be centre and run true, still most of the time the car wants to pull to the right sightly and I still find myself having to correct it to keep it straight...
It's not the roads where I live as I have a RR Sport as well which has also had 4 new tyres and alignment and it's like an arrow, on all and any roads, straight and true as is expected...
If it was like it all the time, it would be easier to pinpoint the problem maybe but its more like 60-70% of the time its off and the rest of the time it's straight and true... It can behave different on the same road as well, one day it will be off and the next it will be true on the same bit of road...
I can take it the dealer for alignment but are they gonna do anything that the Hawkeye doesn't...??? Not only that, it's 6 times the price to take it to the dealer...!!
Car hasn't been in any accidents either so it ain't bent...!!
Just doesn't make any sense and it's driving my OCD mental, I cant bear to look at a wonky steering wheel or have a car that don't drive straight, so much so that if I cant fix the problem, I will get rid of the car.... Drives me mad...
As said, have changed the track rod ends, all the front suspension bushes, steering rack bushes, engine mounts...
The only issue I have at the moment is a air leak in my front near side spring but when the car is running, it runs level, it just dumps the air out when you turn off the car... But I can't believe this will effect the alignment...
Any ideas please...??????
mixja23 is offline
post #2 of 11 (permalink) Old 05-12-2019, 12:48 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 769 Post(s)
Have you tried giving the power steering system a bleed.
mattml430 is online now
post #3 of 11 (permalink) Old 05-12-2019, 02:33 AM Thread Starter
Vehicle: 2007 ML63
Well, I've done the 2-3 times lock to lock more times than I care to remember...!!
Is that what you mean...??
mixja23 is offline
post #4 of 11 (permalink) Old 05-12-2019, 02:35 AM Thread Starter
Vehicle: 2007 ML63
I should say as well, it's worse when its on the highway, a long straight flat road and I almost every time find myself holding it from pulling right....
Low speed around town, it seems mostly ok....
Just above about 40-50mph seems on a straight road, to be a lot worse...
mixja23 is offline
post #5 of 11 (permalink) Old 05-12-2019, 02:38 AM
mattml430's Avatar
Quoted: 769 Post(s)
Iím not totally up to speed on the 164 power steering but when we do it in the 163 itís wheels off the ground, engine off and 20-30 times lock to lock.
When I replaced the engine in my friends ML63 thatís how I bleed the power steering in his.
Has any work ever been performed on the power steering.
post #6 of 11 (permalink) Old 05-12-2019, 02:40 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1519 Post(s)
Remove your right side calipers and see if the slide pins (#340) move freely back and forth.
mattml430 likes this.
43sqd is offline
post #7 of 11 (permalink) Old 05-12-2019, 02:42 AM
mattml430's Avatar
Quoted: 769 Post(s)
Good call Jim.
post #8 of 11 (permalink) Old 05-12-2019, 02:44 AM Thread Starter
Vehicle: 2007 ML63
I'm sure I read for these it's just 2-3 times lock to lock wheels on ground, I may be wrong tho...!!
I've only had the car a few months tbh, it's not needed any steering work since I've had it but the 2 owners before me both had all their work done at dealer.... SO chances are it may have gone in for a dust cap replacement and they've replaced the whole steering system lol...
There's a whole stack of MB invoices in the glove box, I only flicked thru them before, will check again and see if it's had anything done...
Never had this on a car before...!!
mixja23 is offline
post #9 of 11 (permalink) Old 05-12-2019, 02:47 AM Thread Starter
Vehicle: 2007 ML63
Bit out of my scope that lol...
I'm going on holiday this week so it's going in to mechanic for couple of small jobs, I will ask him to check this....
I assume you're suggesting the brakes could be pulling it...??
mixja23 is offline
post #10 of 11 (permalink) Old 05-13-2019, 01:27 PM
Yes.
43sqd is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
johnma
Possible 2007 ML63 Purchase - Convince Me? carlosamg W164 M-Class 0 10-25-2014 07:38 AM
Rear Alignment Gremlins ccrider2 X164 GL-Class 0 03-31-2013 09:06 AM
True or False - Alignment questions steh-fan W126 S,SE,SEC,SEL,SD,SDL Class 23 10-17-2011 07:37 PM
Anybody know what the alignment specs are? Wotseurba W211 E-Class 2 07-29-2011 10:23 AM
Front-end and/or Four-wheel alignment DASola General Mercedes-Benz 0 02-14-2006 07:26 AM
