W164 ML63 Air suspension question - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 04-17-2019, 04:08 AM Thread Starter
Date registered: Mar 2019
Vehicle: 2007 ML63
Weird as it's intermittent, if something was leaking, it would doing all the time I'd have thought...??
Sometimes it goes a week without dropping, sometimes it'll drop every time I park it during the day....
mixja23 is offline
post #12 of 17 (permalink) Old 04-17-2019, 05:30 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1544 Post(s)
As you already know there are too many codes to deal with. You will have to find a mechanic with a Mercedes SDS Scanner to read the codes.
43sqd is offline
post #13 of 17 (permalink) Old 04-18-2019, 03:58 AM
Jay430w210's Avatar
Date registered: Dec 2014
Vehicle: 2007 ML63 AMG, 2005 ML500 SE
Quoted: 5 Post(s)
Under the hood in top of the suspension mount there is a vacuum hose that goes into the air shock that has a brass compression hex nut. I think it’s a 10mm. I hear that those can loosen and leak.
See if that’s loose.
Every time I shut my 63 off when it’s in comfort or auto it goes down and rests on the bump stop. I hear a woosh when you close the door or if you sit in the car after you turn it off for about 20 seconds and it drops. The only time it stays up and not got down to the bump stop is if I press the raise button and it’s completely raised.
Jay430w210 is offline
post #14 of 17 (permalink) Old 04-18-2019, 04:04 AM Thread Starter
Vehicle: 2007 ML63
I bought the Autel scanner as all I've seen people saying this is definitely the best one etc etc...
But having now used it, I'd say that Carly is the better option, it knows there is 70 ECUs in the car and it will get an answer from almost half of them....
As you can see, it has checked the Airmatic ECU and it is showing no faults... And never has done...
So, no idea why the car is dropping like this...
mixja23 is offline
post #15 of 17 (permalink) Old 04-18-2019, 05:53 AM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1692 Post(s)
I think the problem is that you have the Autel MD808 which only scans a few systems. My understanding is that you need the Autel MD802 Elite in order to scan all the car's systems. But I have no hands-on experience with the Autel units. I am only guessing based on reading the experiences of others in the forum. I use SDS myself.
- RODNEY
My Stable:
rudeney is offline
post #16 of 17 (permalink) Old 04-18-2019, 06:03 AM Thread Starter
Vehicle: 2007 ML63
Originally Posted by Jay430w210 View Post
Under the hood in top of the suspension mount there is a vacuum hose that goes into the air shock that has a brass compression hex nut. I think itís a 10mm. I hear that those can loosen and leak.
See if thatís loose.
Every time I shut my 63 off when itís in comfort or auto it goes down and rests on the bump stop. I hear a woosh when you close the door or if you sit in the car after you turn it off for about 20 seconds and it drops. The only time it stays up and not got down to the bump stop is if I press the raise button and itís completely raised.
Will check that, thank you....
Yeh, mine seems weird as it doesn't do it all the time, sometimes when it does, it can be one side or both, it only happens about 40% of the time too...
But yeh, I always here that woos of air tho as I'm walking away from the car...!!
mixja23 is offline
post #17 of 17 (permalink) Old 04-18-2019, 06:10 AM Thread Starter
Vehicle: 2007 ML63
Well, i did do a bit of homework before I bought it, you can see the model comparison on Autel website as to what each model does and doesn't do, looked to me like the 808 did everything the 802 does and more, there was about $10 difference in price, hence I went for the 808....
I wish I could afford SDS lol, but tbh, for what I need it for which is nothing more than checking, Carly is perfect and seems to do a lot more than the Autel does...
If there is any issue, it goes to the mechanic anyways and he has Star and SDS...
As you can see in the pics, Carly covers pretty much everything.... Plus all the OBD stuff and Live Data, I believe that includes steering angle as well.......
Only thing I noticed that Autel does that Carly doesn't yet is Battery Management...
ID:	2505532   Click image for larger version
ID:	2505534   Click image for larger version
ID:	2505536   Click image for larger version
ID:	2505538   Click image for larger version
ID:	2505544   Click image for larger version
ID:	2505546   Click image for larger version
ID:	2505548   Click image for larger version
mixja23 is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
:: ECS Tuning :: Performance Air Filters For Your W164 ML63 AMG (2007-2011) ECSTuning W164 M-Class 0 06-19-2015 01:04 PM
Arnott Air Suspension Products Intro New Front Air Strut for '06-'11 ML63 AMG ArnottDoug Arnott Inc. 0 04-20-2015 12:49 PM
Question about Rear Air Suspension....Leak? skiman W211 E-Class 8 01-18-2013 11:31 AM
Intake Air Temperature and Design senorking C208/A208 CLK-Class 4 03-29-2011 07:48 AM
