Rear Differential Bearing - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 03-22-2019, 05:31 PM Thread Starter
Diesel_Nut's Avatar
Date registered: Feb 2004
Vehicle: 2007 ML320 CDI
Quoted: 2 Post(s)
Hi
I have a 2007 320CDI with 142k that has a growl from the rear that gets louder with speed. The noise levels out at about highway speeds.
Looking under, I found the differential bearing at the left half shaft to have radial play, maybe 0.5mm, total. The right side is fine. It is definitely the bearing inside the diff., not the axle CV/coupler.
Does anyone have experience with this they can share?
Is the bearing serviceable without entire diff rebuild?
Thanks,
John
John
07 ML320 CDI
Diesel_Nut is offline
post #2 of 9 (permalink) Old 03-23-2019, 12:41 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1530 Post(s)
Here are the instructions.
43sqd is offline
post #3 of 9 (permalink) Old 03-23-2019, 06:50 PM Thread Starter
Diesel_Nut's Avatar
Quoted: 2 Post(s)
Thanks for the speedy reply, 43sqd.
It looks like the instructions you sent are for the outer bearing, at the wheel.
My bearing play is at the inboard end of the axle shaft, inside the differential. See annotated picture.
Do you have any information on that bearing?
Name:	Diff annotate.jpg
John
07 ML320 CDI
post #4 of 9 (permalink) Old 03-24-2019, 12:21 AM
I can't find anything on a 230CDI. Is it a 320CDI?
If so, please update your profile to indicate that.
43sqd is offline
post #5 of 9 (permalink) Old 03-24-2019, 01:16 AM
Is this what you are looking for?
43sqd is offline
post #6 of 9 (permalink) Old 03-28-2019, 05:52 PM Thread Starter
Diesel_Nut's Avatar
Quoted: 2 Post(s)
Well... it is R&I for the seal. I feel play in the left side bearing in the differential that I am thinking is making the growl.
I will put the vehicle on 4 jack stands this weekend and (carefully) run it in drive, trying to find out where the growl is coming from.
I was interested to see if anyone else has a similar problem. It does not get louder with turns or accelerating or engine braking.
Thanks for all the help. I will let you know how it goes this weekend.
post #7 of 9 (permalink) Old 03-28-2019, 07:01 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 829 Post(s)
Thanks,
John
No, it is not. Differential is serviced as a unit. There are no specs or repair instructions.
Driving lifted may not reveal too much. With no load it all may be nice and quiet. Traction system will try to take action applying brakes to wheels that turn faster. Multiple faults in traction system will follow.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 9 (permalink) Old 03-29-2019, 12:25 AM
To me the left and right seals look like bearings. Look at the roller balls on both.
EPC supplies both seals/bearings.
ID:	2500090   Click image for larger version
43sqd is offline
post #9 of 9 (permalink) Old 04-20-2019, 05:13 PM Thread Starter
Diesel_Nut's Avatar
Quoted: 2 Post(s)
Well, it turns out I misdiagnosed the noise, and the problem is the RR axle bearing.
Earlier, the sound did not increase with turns. Now, if I turn hard left, the noise gets louder.
I also had a MB master tech inspect it with the same conclusion.
So, I will replace the wheel bearing.
Thanks for the R&I instructions, 43sqd. I may pay someone to do that job. I have access to a good shop press, but not the time to get into it.
The MB master tech (at a private shop) quoted $400 in labor. Either he is very pricey, or knows something about the work required.
John
John
07 ML320 CDI
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
W220 Flex Discs, intermediate bearing and centering sleeves replacement dtnel W220 S-Class 17 04-05-2017 10:54 AM
Rear differential mounts w/o dropping rear diff completely? kelley312c1 W124 E,CE,D,TD Class 8 09-07-2016 01:55 AM
SERVICE MANUAL & INDEX 420 SE W126 S,SE,SEC,SEL,SD,SDL Class 3 08-29-2008 12:40 AM
1988 300 se rear axle dgray W126 S,SE,SEC,SEL,SD,SDL Class 2 08-11-2008 06:55 PM
