OM642 CPS adventure - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 01-03-2019, 04:54 PM Thread Starter
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 265 Post(s)
OM642 CPS adventure
This is on an Ď08 with 120K.
Had a failure to start following a 2 hour ride. Stopped for a humanity break and engine would crank, but not start. Had driven through rain most of the way though not sure if it fits in.
Waited about 40 minutes and engine started, drove another 30 minutes with no trouble. No CEL and full power.
Fast forward 2 months. Drove the ML on a 60 mile route making stops along the way. Raining. Mrs drives the already warm vehicle a couple of miles, makes a short stop, and engine cranks-no start.
I pick her up and finish the purpose of the trip. We go back about an hour later and engine starts and we drive home.
No codes. Ordered a CPS as this reminded me of a gas CPS failure mode.
Part arrived and I changed it today. NOT an easy task on these engines. Requires removal of the drivers side air filter and working blind. There is a heat shield covering the sensor and then the sensor. The sensor has three contacts and I measured the old vs new to see if there was a difference.
New: outer connections had resistance, one outer to middle had resistance and the other outer to middle had none.
Old: outer connections had no resistance, one outer to middle had resistance (lower than the new one) and the other outer to middle had none.
Installation took too long and I have new respect for those folks who can work via mirrors. I worked from above and only briefly considered taking the under panels off as itís Winter here and the garage floor is wet and cold.
Engine started somewhat quicker than before.
Iíll report further as we get some miles on it.
YMMV
Skippy
Sent from my iPad using Tapatalk
Skippy,
SkippyJasper is offline
post #2 of 15 (permalink) Old 04-03-2019, 04:06 AM Thread Starter
Quoted: 265 Post(s)
I thought I had cured this problem, but....
Was with the Mrs and we had gone on a 40 mile trip, couple hour wait, another short jaunt for breakfast. Upon return it cranks, no start.
Fuel pump is not engaging when key is in position 2. While I wait for whatever needs to be cooled down I fiddle with relays under the hood and swap one for the fuel pump relay in the back. Turn key, pump starts, engine runs. Drive home.
I figured the relays MIGHT be tired and ordered a batch from Autohausaz. They have not arrived yet.
I swapped the fuel pump relay from my Ď07 Bluetec. All seemed fine until...
Yesterday I went on a short journey of 7 miles and stopped briefly. Truck was turned off and locked.
Upon return some 5 minutes later I get crank but no start.
I wait for an hour and pump starts and I drive home.
Iíve started checking general connections, both positive and grounds.
Any thoughts on next steps? Relays expected later this week.
Thanks, Skippy
Skippy,
post #3 of 15 (permalink) Old 04-04-2019, 02:28 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1501 Post(s)
Skippy, all that writing and you do not say who you ordered the sensor from and what was the part number?
Is the problem worse or the same as before?
43sqd is offline
post #4 of 15 (permalink) Old 04-04-2019, 03:21 AM Thread Starter
Quoted: 265 Post(s)
OM642 CPS adventure
CPS sensor was from Autohausaz 642153072805.
Problem today is still intermittent. Drove 50 miles yesterday with a 30 minute stop and no issues.
Relays ordered from Autohausaz, but not here yet.
3 - 0025421119 (4 prong fuel pump relay in rear compartment and 2 in front (engine compartment).
2 - 0025421419 (5 prong in front compartment).
2 - 0025422619 (4 prong in front compartment).
1 - 0025427619 ( 5 prong in front compartment).
First 7 are Hella and the last is Genuine Mercedes.
My thoughts are that the front compartment gets much warmer especially after engine shutdown.
This grouping will replace all of the relays in the front compartment plus the fuel pump relay.
Likely overkill, but I am trying to eliminate potential problems.
I scanned the car again yesterday - no codes. Carsoft MBII.
Skippy,
post #5 of 15 (permalink) Old 04-04-2019, 06:16 AM
Skippy, what is you full vin#?
43sqd is offline
post #6 of 15 (permalink) Old 04-04-2019, 06:52 AM Thread Starter
Quoted: 265 Post(s)
4JGBB22E68A348961
Finally got my a## in gear and bench tested the relays. All seem fine. Tested resistance across the coil and then confirmed good contact across the load points. This was with the relays cold (ambient is 30F).
I looked for the old CPS, but think I tossed it.
Appreciate your efforts.
Skippy,
post #7 of 15 (permalink) Old 04-04-2019, 08:22 AM
According to your vin#, you purchased or were given the wrong sensor.
43sqd is offline
post #8 of 15 (permalink) Old 04-04-2019, 07:18 PM Thread Starter
Quoted: 265 Post(s)
OM642 CPS adventure
Buggers! I appreciate the information.
The EPC info would capture any updates to part numbers?
Oddly, the Autohausaz ordering page shows the following:
ĎCross References: 642153072805 6429050000 6429050000Yí
It states this applicable to a variety of engines:
Dodge Sprinter 2500, Sprinter 3500
Freightliner Sprinter 2500, Sprinter 3500
Mercedes E350, C300, ML350, S550, GL450, C280, GLK350, C230 Sport, Sprinter 2500, CLS550 & more
Iíll pursue getting the correct sensor through a local dealer though itís 1 hour to the south or 1.5 hours to the north of here.
The job itself isnít exactly a walk in the park either.
Skippy
Skippy,
post #9 of 15 (permalink) Old 04-05-2019, 01:03 AM
Order it here.
https://www.mbpartsworld.com/auto-parts
Also, here is a copy of your DATA Card with all the option codes.
43sqd is offline
post #10 of 15 (permalink) Old 04-05-2019, 03:57 AM Thread Starter
Quoted: 265 Post(s)
Thanks.
Item ordered.
Last time I replaced it was from above after removing the left air filter. Needed a mirror to see it. I recall that I didnít work from under the car as it was early January and things were mighty cold.
Perhaps Iíll try it from under this time.
Skippy,
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rvschulz
