OM642 CPS adventure - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 04-14-2019, 03:49 PM Thread Starter
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 265 Post(s)
Received the cps and confirmed itís the latest generation.
Took the old one off (working under the car this time) and found it to be second generation and to be genuine MB.
I installed the new and was able to carefully note that it was seated properly and that the electric clip was engaged.
Proceeded to install the heat shield and dropped the bolt four times, but only found it three times. Itís an M6 bolt which is small.
Found a replacement at my local hardware.
Iím hoping itís use doesnít void any remaining warranty from MB, LOL.
Time will tell if this cures things.
Sent from my iPad using Tapatalk
Skippy,
SkippyJasper is offline
post #12 of 15 (permalink) Old 04-15-2019, 01:32 PM
Date registered: Mar 2009
Vehicle: 2003 E500, 2008 ML320CDI
Quoted: 7 Post(s)
Have you ever noted the fuel level when you got the no-start condition? We experienced the exact symptoms you describe, but only when the fuel dropped below half tank. I solved the issue by replacing the in-tank fuel pump.
SkippyJasper likes this.
81willis is offline
post #13 of 15 (permalink) Old 04-15-2019, 07:20 PM Thread Starter
Quoted: 265 Post(s)
Thanks for your experience. I cannot, with confidence, say what the fuel level was when the events occurred.
Iíll start running it below half tank and see what happens.
Skippy,
post #14 of 15 (permalink) Old 04-16-2019, 10:21 AM Thread Starter
Quoted: 265 Post(s)
81Willis,
What led you to suspect the fuel pump?
Skippy
Skippy,
post #15 of 15 (permalink) Old 04-16-2019, 11:55 AM
Quoted: 7 Post(s)
I bought the truck used and the people I bought it from had mentioned that it probably needed a fuel pump, apparently they had trouble with it and the dealer diagnosed it as a bad pump.
81willis is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
