android radio - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 05-14-2017, 10:02 AM Thread Starter
Date registered: Nov 2013
Vehicle: 2000 S500 and ML350
Quoted: 16 Post(s)
android radio
I wonder if anyone had installed android radio in ml350 and can share experience.
tritron is offline
post #2 of 17 (permalink) Old 05-14-2017, 11:21 PM
Whiteys500's Avatar
Date registered: Aug 2012
Vehicle: 2000 S 500, 2008 ML63 AMG
Quoted: 11 Post(s)
I have the Avin Avant 2 unit in MY 2008 ML63 and i love it.
Install can be a little daunting if you don't know your way around wires and a soldering iron.
Hardest part i found was finding a Hot on ACC Wire in the cluster i was working on to Turn the unit on.
Also the fit in the dash was rather TIGHT but it fits and looks Like OEM to the untrained eye.
But with a few apps because IMHO the Stock home menu is a little "Limiting" i use CarDashdroid with Tasker set up to open on Boot and its just like having a Android tablet in your dash.
I also have a hot spot dedicated for my car so i can stream Pandora live google maps and You tube if i feel the need with no issues.
It retains the Factory Amp so your Sub/ Harmon kardone system will still sound great (Even better because you can more finely tune the sound profiles through the on board OS. only thing is if you have the HK Sound in your ML you'll need the Adapter which when i bought the unit they had a coupon code for 150 off so it was basically free, But if no HK or Fibre Optics its just Plug and play.
The Mic on board the unit works for BT calling. basically an all in one unit to fix/Replace all the Woes that the Command unit was lacking. There is a realy god Write up on here of the unit Install / Review. Just look up Avin Avant 2 Review and look for the BENZWORLD post and all the info is right there.
Definitely Worth the money
Whiteys500 is offline
post #3 of 17 (permalink) Old 05-16-2017, 12:49 PM
james.calton1's Avatar
Date registered: Mar 2008
Vehicle: 2012 GL 450 4Matic
Quoted: 181 Post(s)
Me and several others have done the AVIN avant 2. It works well. There are a few DIY's on the forum
james.calton1 is offline
post #4 of 17 (permalink) Old 05-16-2017, 12:52 PM
Quoted: 181 Post(s)
It's also probably cheaper then adding Sirius xm and Bluetooth to the car. Those kits are expensive and you get it all in one shot here. I stream Sirius xm via my iPhone and it works great.
post #5 of 17 (permalink) Old 04-07-2019, 08:05 PM
Date registered: Apr 2019
One thing that i am wondering is that when you set the time on the Avin Avant 2 does it set the time on the clock on the instrument cluster.
Peter Waring is offline
post #6 of 17 (permalink) Old 04-08-2019, 08:12 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1597 Post(s)
I seriously doubt that. While it's possible that AVIN could make its radio send out the proper CAN bus signals to to send the clock data to the ICM, it's not likely. If you do remove COMAND and want to be able to set the ICM clock, you'd need to hook up to SDS and re-code the ICM to "COMAND Present - NO" . That will enable an option on the ICM to manually set the clock via the steering wheel buttons and menus on the MFD.
- RODNEY
My Stable:
rudeney is offline
post #7 of 17 (permalink) Old 04-10-2019, 12:37 PM
Quoted: 181 Post(s)
You are correct. You are unable to change the clock via the AVIN unit.
post #8 of 17 (permalink) Old 04-12-2019, 12:37 PM
Date registered: Jul 2006
Vehicle: Current: '07 SL550, '06 ML350 - Past: '99 ML320 (Sold), '98 SLK230 (Wrecked), 05 SL500 (Wrecked)
Quoted: 41 Post(s)
I have been changing the dash clock on my 06 ML350 using the MFD settings and the steering wheel buttons. I never used the Comand to set the time. In fact I can't even find an option to sync the clock to the Comand or Navigation.
On my SL550 I was afraid I may have a problem, but in the settings the clock option is NV-SYNC On/Off. Once you turn NAV-SYNC OFF, you can set the time manually using the steering wheel buttons
Dudeman is offline
post #9 of 17 (permalink) Old Yesterday, 06:58 AM
Vehicle: 2007 W164 (320CDI 4Tech)
Honestly, this is the single most wanted thing in my car. The stock head unit is so outdated, it's humiliating. I've done my research and I will probably go with the Avin 9" unit.
There's a great install step by step guide, however it looks like it's a easy install. So, that's what I'll probably do first.
DONPhantasmo is offline
post #10 of 17 (permalink) Old Yesterday, 01:16 PM
Deja-vue's Avatar
Date registered: Dec 2003
Vehicle: 2011 ML350 BlueTec, 2008 ML350 4Matic
Quoted: 15 Post(s)
I don't have an Android System, but am very happy with the Pioneer AVIC 7201, comes with more stuff than I can list here. It comes with it's own Backup Camera, got Life Traffic GPS Navi, I usually listen to Pandora or from a Flash card. I have that same System in both of my ML's, and as they do cost quite a bit more than Androids, they are well worth it.
Deja-vue is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
