How to clear gearbox... memory ? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 03-25-2009, 01:38 PM Thread Starter
Vehicle: Mercedes ML 420 CDI
Arrow How to clear gearbox... memory ?
I've just arrived from my dealer.
It seems that they expect a new software for the 420 CDI gearbox, but in the meantime, they cleared the learning settings on my car's gearbox.
As you probably know, the gearbox will try to learn how you drive (fuzzy logic), but I drive long periods of time in traffic jams (most of the time) so NOW it seems like another car!
It's changing gears much faster!
Is there a code or something to do this on my own ?
On my wife's BMW x3 it's possible by holding down the acceleration pedal 30s of the first position of the key.
Courage is offline
post #2 of 12 (permalink) Old 03-26-2009, 04:50 AM
Pligs76's Avatar
Date registered: Oct 2008
Vehicle: ML 550 [w164] 285kw
Hi Courage,
According to one of the German forum's this is the way to reset the 7G-gearbox from MB:
1.) Turn ignition key into position 2. Do not start engine.
2.) Puch accelerator all the way down to KICKDOWN position. Keep this position for 5 seconds.
3.) With foot still holding accelerator down, turn ignition key back to position 0.
4.) Wait for approx. 2 minutes until the gearbox has reset.
The gearshifts will seem agressive to begin with. This is normal until it has learned the new changing patterns.
Hope this helps.
On another note, others have complained over increased consumption after the November 2008 "S-B-27.60/61j" gearbox upgrade. Is this an even newer upgrade?
Cheers
Pligs76 is offline
post #3 of 12 (permalink) Old 03-27-2009, 02:50 AM Thread Starter
I don't know about this upgrade.
My dealer has nothing for 420 CDI, only for 320 CDI...
This is a big question... thre is something new for 420 CDI and my dealer doesn't have it ?
My car is produced in oct 2007.
Courage is offline
post #4 of 12 (permalink) Old 04-02-2009, 01:38 AM Thread Starter
Yuk
My model 420 CDI it's not included in this gearbox software update ;(
All Models Equipped with 7G-Tronic Transmission (NAG2)
Uncomfortable Shift Quality of 1-2, 3-2 and 2-1 Gear Shifts
Revision: Applicable Models Updated
Model 164.122/125/172/175/177/186/822/825/871/886
420 CDI has designation 164.128
Courage is offline
post #5 of 12 (permalink) Old 04-17-2009, 09:04 AM
Date registered: Apr 2009
Vehicle: 2007 ML350
Does the "learning gearbox" only pertain to the CDI models?
KoalaEatingTree is offline
post #6 of 12 (permalink) Old 04-24-2009, 12:32 PM
Date registered: Nov 2005
No, it is a feature of 7G-Tronic transmission.
->Merc is the way to go
CycloneRcr is offline
post #7 of 12 (permalink) Old 04-25-2009, 07:10 AM Thread Starter
Almost all modern gearboxes have this thing.
It's more or less advertised by producers...
Courage is offline
post #8 of 12 (permalink) Old 04-25-2009, 10:49 AM
adly's Avatar
Date registered: May 2008
Vehicle: ML350 06, SL300 91
how we want to know the gearbox has reset?any sound or whatsoever?im too ignorant....sorry `bout that
adly is offline
post #9 of 12 (permalink) Old 04-25-2009, 11:37 AM
asianml's Avatar
Date registered: Sep 2005
Quoted: 2 Post(s)
There isn't going to be a chime or anything to let you know its been reset. The only way to tell is if you drive it and you notice a difference.
2002 Mercedes-Benz ML320 (sold)
2011 Chrysler Town & Country
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5
asianml is offline
post #10 of 12 (permalink) Old 05-20-2009, 01:32 AM
Date registered: Mar 2008
Vehicle: 2006 Mercedes-Benz ML320 CDI Sport - Fully Loaded!
On step 4, do you have to continue holding the accelerator pedal down for the two minutes, or do you take your foot off once you have turned the ignition key back to position 0?
ryan.stephens is offline
  Mercedes-Benz Forum > Mercedes-Benz Vans/Trucks/SUV/Others > W164 M-Class
Need to clear ADS fault memory Axilane R129 SL-Class 2 05-12-2007 04:53 AM
transfer gearbox /gearbox parts for 463 G-wagen redao G-Class 1 03-30-2007 09:42 AM
clear tail lights & clear turn signals? vi_pn_babe W202 C-Class 0 05-16-2006 05:25 PM
Clear / Clear & Red Taillights Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 9 05-01-2002 06:15 PM
Clear + clear/red taillights for W126 Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 03-05-2002 05:08 PM
