HELP !! 1998 multi CD Changer vrs. 2000 CD changer? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 01-03-2003, 01:53 PM Thread Starter
Benza's Avatar
Date registered: Nov 2002
Vehicle: 2001 ML 55AMG
Quoted: 2 Post(s)
So far I have installed a 2000 MCS unit in my 1998 ML 320. My 1998 CD changer no longer works, so I bought a 2000 CD Changer (MB part# A 163 820 13 89) which from what I understand is partially Fiber Optic. I also know I need to install the 2000 wire harness in order for the 2000 CD Changer to work. However, I am looking at the 2000 CD Changer and I don't see a seperate Fiber Optic cable plug anywhere on the Multi CD Changer? Is there 1 that I just don't see or is it part of the harness?
Thanks,
Benza
Benza is offline
post #2 of 11 (permalink) Old 01-03-2003, 02:14 PM
kenyee's Avatar
Vehicle: 2001 ML320
Quoted: 2 Post(s)
pre-2001 was *not* fiber optic...plain copper
kenyee is offline
post #3 of 11 (permalink) Old 01-03-2003, 02:22 PM Thread Starter
Benza's Avatar
Quoted: 2 Post(s)
Re: pre-2001 was *not* fiber optic...plain copper
So if I run a new wire harness, that would solve this problem?
Benza
Benza is offline
post #4 of 11 (permalink) Old 01-03-2003, 02:33 PM
William Monte's Avatar
Vehicle: 1999 ML430, 2012 ML350
Yes, you need to run a 2000 harness to get you CD..........
up and running again. Crazy isn't it. 98 & 99 wiring the same then some sort of change in 2000 and another change in 2001 plus 3 different CD changers. BTW, where did you get your MCS?
William Monte is offline
post #5 of 11 (permalink) Old 01-03-2003, 02:54 PM Thread Starter
Benza's Avatar
Quoted: 2 Post(s)
Re: Yes, you need to run a 2000 harness to get you CD..........
I just looked at the wire harness plug for the 1998 (it looks the same as the 2000) and plugged it in to the 2000 Multi CD Changer and it plugged right in. (of course it didn't work) But if the 2000 is not fiber optic, and the plug is the same I wonder if there is and adapter or maybe an adapter could be fabricated?
Any ideas?
Benza
Benza is offline
post #6 of 11 (permalink) Old 01-03-2003, 03:20 PM
Bora20's Avatar
Date registered: Sep 2002
Vehicle: 2000 E320S4M
Maybe you can just rewire the connectors in the existing harness to work properly. But ...
But you will have to find a pin-out diagram of the connectors.
Bora20 is offline
post #7 of 11 (permalink) Old 01-03-2003, 03:56 PM Thread Starter
Benza's Avatar
Quoted: 2 Post(s)
Re: Maybe you can just rewire the connectors in the existing harness to work properly.But
That is what I was thinking. If anyone knows the correct pin diagram or where I can get it please let me know.
(William Monte) It is crazy RE: all the different CD Changer changes!! What was MB thinking[?]
By the way, I purchased the MCS unit on EBAY.
Benza
Benza is offline
post #8 of 11 (permalink) Old 01-03-2003, 04:57 PM
kenyee's Avatar
Vehicle: 2001 ML320
Quoted: 2 Post(s)
Not sure it's just wiring
There was a 3rd party adapter to allow you to hook up a <a href=http://http://www.keysolutions.com/M-Class.nsf/8178b1c14b1e9b6b8525624f0062fe9f/DD33E42A4F4D5DC2852565C500684D78>Panasonic CD changer</a> to 1998/1999 MLs. The adapter doesn't work w/ the 2000 model.
For 2001, you have to get a Becker optical CD changer.
kenyee is offline
post #9 of 11 (permalink) Old 01-03-2003, 05:04 PM
Vehicle: '00 ML320, '07 E550
Re: Re: Maybe you can just rewire the connectors in the existing harness to work properly.But
Benza
Benza, It should work unless the plug on the back of MCS was not plug in? Can you eject the CD magazine? If both side are plug-in then the last thing you can do is recycle the MCS power( make sure you have the code). I can compare the wiring if you want.
Tony
tony is offline
post #10 of 11 (permalink) Old 01-04-2003, 01:55 AM
Date registered: Jan 2003
wiring
email me specifics and i will send you oem wiring diagrams...........shhhhh
[email protected]
jbmbusa is offline
