ATA status indicator(E33) - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-23-2019, 08:54 AM Thread Starter
dramos's Avatar
Date registered: Dec 2015
Vehicle: 2000 ML320 LHD
Quoted: 149 Post(s)
Send a message via Yahoo to dramos
Hello,
When E33 does not flash in position 2, it means the transmitter key is not recognised.
What would be the possible culprit/s?
43sqd, Witek, DrX, Art, Matt can you please share your knowledge on this.
dramos is online now
post #2 of 9 (permalink) Old 07-23-2019, 12:25 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 916 Post(s)
Does in start? Starts and dies after about a second?
Witek_M is offline
post #3 of 9 (permalink) Old 07-23-2019, 02:33 PM Thread Starter
dramos's Avatar
Quoted: 149 Post(s)
Witek,
Car starts fine.
The only problem is inability to sync remote key fob.
post #4 of 9 (permalink) Old 07-23-2019, 02:47 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
Quoted: 653 Post(s)
If it flashes at least once when you turn to position 1, then stops flashing (and remains off) when you turn to position 2, then you get engine start with position 3, then that is normal function.
If you leave it in position 1, flash will repeat at 2 second intervals.
DrX is offline
post #5 of 9 (permalink) Old 07-23-2019, 02:57 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 916 Post(s)
Originally Posted by dramos View Post
Witek,
Car starts fine.
Transponder coil reads RFID chip at the base of the key. That is used for immobilizer.
Remote locking is separate function.
Witek_M is offline
post #6 of 9 (permalink) Old 07-23-2019, 03:11 PM Thread Starter
dramos's Avatar
Quoted: 149 Post(s)
Witek,
Remote sync procedure says in position 2, E33 indicator should light up to recognise key.
If I recall clearly, the normal pattern of the E33 red led under normal circumstances is repeated per sec flash in position 1, steady lighting in position 2, no lighting in position 3 then delayed repeated flash if car is locked with remote.
Correct me where I missed it.
post #7 of 9 (permalink) Old 07-23-2019, 08:05 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 916 Post(s)
Witek,
I have never examined what happens in position 1. It's just not a sexy position.
But just for sake of general knowledge I have observed ATA LED. It flashes every few seconds.
WE47B1ME and dramos like this.
Witek_M is offline
post #8 of 9 (permalink) Old 07-24-2019, 01:50 PM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 789 Post(s)
Send a message via Skype™ to art_arev
As Witek said remote function has nothing to do with E33.
E33 indicates that the car is recognizing the chip (start function).
Did you change your batteries? Try getting new proper brand batteries & sync
Art
art_arev is online now
post #9 of 9 (permalink) Old 07-24-2019, 03:00 PM Thread Starter
dramos's Avatar
Quoted: 149 Post(s)
Glad you're here Art.
I got very good new batteries but no luck with sync in both remote keys.
