Verifying cooling fan/fan assembly/radiator fan is dead? - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 07-14-2019, 05:35 PM Thread Starter
ed7c9's Avatar
Date registered: Jan 2018
Vehicle: 01 ML55
Quoted: 56 Post(s)
MB calls it the "fan assembly" but for the ML55 it's the electric fan that sits below the upper radiator hose (preaching to the choir).
I tried jumping the relay but it won't kick on. I don't have any tester relays but I was able to jump the two relays next to K26 and think the fan is dead. I wanted to check and see if there's any other methods to try before I get a replacement. These things aren't cheap!
ed7c9 is offline
post #2 of 9 (permalink) Old 07-14-2019, 09:05 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 306 Post(s)
ed,
Post #4 may be of some assistance.
- https://www.benzworld.org/forums/w16...oling-fan.html
edit
Im sure you are aware of this too? for ML55s and ML55s
one more attachment....
Name:	Fan Fuse ML 55 & 500 #1.jpg
khomer2 is offline
post #3 of 9 (permalink) Old 07-15-2019, 09:35 AM Thread Starter
ed7c9's Avatar
Vehicle: 01 ML55
Quoted: 56 Post(s)
great info, thank you. didnt think about that fuse, will check tonight.
ps that fix on the fan was pretty unique
ed7c9 is offline
post #4 of 9 (permalink) Old 07-16-2019, 04:27 AM Thread Starter
ed7c9's Avatar
Vehicle: 01 ML55
Quoted: 56 Post(s)
Well fuse was okay. Does anyone have a wiring diagram for that fan?
ed7c9 is offline
post #5 of 9 (permalink) Old 07-16-2019, 05:38 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 917 Post(s)
What problems are you having? Engine over 110 C, a/c not cooling at idle?
Few relevant threads.
https://www.benzworld.org/forums/w16...ight=ML500+fan
Witek_M is offline
post #6 of 9 (permalink) Old 07-16-2019, 05:40 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1556 Post(s)
Here is the diagram and legend.
With the key out of the ignition, check the RED wire for 12v+ and the BROWN wire for GROUND.
Then, with the eng. running, monitor the WHITE wire & follow instructions for as of 2001.
File Type: pdf Remote Desktop Redirected Printer Doc. #2pdf.pdf (308.9 KB, 10 views)
File Type: pdf Remote Desktop Redirected Printer Doc. #3pdf.pdf (9.4 KB, 9 views)
43sqd is offline
post #7 of 9 (permalink) Old 07-22-2019, 07:30 AM Thread Starter
ed7c9's Avatar
Vehicle: 01 ML55
Quoted: 56 Post(s)
Thanks gents. fan was toast. did all the test and failed. picked up a Chinese one on eBay for $240. working great so far. not ideal but OEM unit cost more than the E60 BMW I just picked up on facebook marketplace so I went with it. If I find a low mileage, OEM unit down the road I will pick it up. nice to have piece of mind at least and cold air at idle.
ps - dead fan did trigger the coolant level indicator up front. finally turned off when I installed the ebay one.
ed7c9 is offline
post #8 of 9 (permalink) Old 07-25-2019, 07:28 PM
dreamkacher's Avatar
Date registered: Jul 2017
Vehicle: 2003 Mercedes W163, ML500
Quoted: 2 Post(s)
Hi. I have a 2003 ML500 V8 and my radiator fan went out. According to my Mercedes mechanic, it could have just gone out or my muffler shop shorted it out while welding the catalytic converter. Either way, I'm stumped trying to find a replacement. I got one from parts geek for 700, and it LOOKS the same, but the final 2pin connection has a small blockage in the connector. I thought I would try and tear that bit out with a screwdriver. It connected after that, but then the fan and dash lights came on WITHOUT THE KEY IN IGNITION!! I immediately disconnected and took the unit out. Question: Is it obviously NOT the right part or do I need to do some type of connection sequence for My Mercedes (Silver Girl) to "recognize" the fan? Or do I just try and find one with the right matching connector? Everything "looks" exactly the same on the new fan, even the connector, except for that tiny molded plastic that would not let it connect. I'm so confused, but I love this old car! Any ideas?
dreamkacher is offline
post #9 of 9 (permalink) Old 07-25-2019, 08:51 PM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 232 Post(s)
No need to double post if someone doesn't get back to you right away.
43sqd likes this.
WE47B1ME is offline
