Random misfire/ Fuel trim - Mercedes-Benz Forum
post #1 of 62 (permalink) Old 06-25-2019, 03:42 PM Thread Starter
Date registered: Mar 2019
Vehicle: 1998 ML320 (W163)
Quoted: 27 Post(s)
I am consistently getting the following fault codes under acceleration in my 98 ML320: P0170, P0173, P0301,P0304, P0302, P0300. I have fairly recently (January of 2019) replaced the spark plugs, coil packs, both the fuel and air filter, and the fuel pump. What else could cause these fault codes? I have very little power above 4000 RPM and virtually none above 5000 RPM. Around 62 MPH with my foot to the floor, but not on the kickdown, it misfires and the check engine light starts to flash.
Name:	Fault Codes 6-25-19.jpg
leeadrian75 is online now
post #2 of 62 (permalink) Old 06-25-2019, 04:29 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 254 Post(s)
Disconnected MAF to see if it will run better.
Also check all your vacuum lines for leaks.
Check your cats too.
khomer2 is offline
post #3 of 62 (permalink) Old 06-25-2019, 04:36 PM Thread Starter
Quoted: 27 Post(s)
How would I check the vacuum lines and the cats?
Next time I take the car I will disconnect the MAF sensor and see if it still acts up
post #4 of 62 (permalink) Old 06-25-2019, 06:28 PM
khomer2's Avatar
Quoted: 254 Post(s)
With the vacuum lines, very carefully inspecting them visually for breakage/cracks OR do a smoke test.
For cats, use a mallet for a quick rattle test. Use the search feature to look for further testing of a bad cat(s).
khomer2 is offline
post #5 of 62 (permalink) Old 06-25-2019, 06:59 PM Thread Starter
Quoted: 27 Post(s)
Upon inspection, I did see that the hose clamp after the MAF sensor wasn't tightened fully, I tightened it and unplugged the MAF sensor. I haven't had a chance to road test because it's about to storm near my house, I will try tomorrow.
post #6 of 62 (permalink) Old 06-26-2019, 01:21 PM Thread Starter
Quoted: 27 Post(s)
After driving without the MAF sensor connected I did get more power once I was at speed, around 50 MPH. But before then I still have the same issue where I have no power above 4000. It still misfired though and I got the following codes the first time I had my foot down around 60 MPH after that it was fine: P0110, P0100, P0304, P0305, P0301, P0300.
Name:	Fault Codes 6-26-19.jpg
post #7 of 62 (permalink) Old 06-26-2019, 01:32 PM
khomer2's Avatar
Quoted: 254 Post(s)
Looks like clogged cats.
The clogged cat is giving codes: P0300, P0304, P0305
Causes increased exhaust back-pressure. You can test this back-pressure by using a gauge at the upstream O2 sensor port.
The p0100 p0110 is your MAF disconnected.
Plug it back in, erase the codes.
And re-test drive.
khomer2 is offline
post #8 of 62 (permalink) Old 06-26-2019, 01:58 PM Thread Starter
Quoted: 27 Post(s)
And re-test drive.
I will plug it back in, erase the codes, and retest. Is there any actual way to unclog the cats? If it's any help the car sat without being started for 6 to 7 years.
post #9 of 62 (permalink) Old 06-26-2019, 02:58 PM Thread Starter
Quoted: 27 Post(s)
I took the car out for a test drive, still gave me fault codes, this time: P0304, P0302, P0301, P0300.
This time I took a video of it: https://drive.google.com/open?id=1--...D5QgGbHlIRvSny
The only reason the truck shifted is because I took my foot off the gas when it started losing power, however after 60 it wouldn't upshift so you can really see what it's doing.
post #10 of 62 (permalink) Old 06-26-2019, 03:58 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 871 Post(s)
Those codes should have associated freeze frame data. Retrieve it and post.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
