BASS/ESP issues New info RECALL 2000 merc. - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 06-22-2019, 02:41 PM Thread Starter
wicked1's Avatar
Date registered: Feb 2015
Vehicle: 2000 ML 320
Off & on I have had BASS light or BASS ESP light come on.
Replaces the Break light relay switch-
ABS motor brushes the
Lights went off for a week but BASS
came back on again with no brake lights
Situation turned critical on way home. I used Cruze control and after about 10 min my car started speeding up to about 70mph
I couldnít stop it. I have driven in bad snow conditions & probably what saved me. I finally slammed on brakes & kept jamming cruise control arm back-and-forth
And car finally stopped just short of intersection.
Then a new thing started happening ... car would just stop in traffic.
Took me 3 separate tries to get car home. Seems as car or bass issue heated?
or ran thatís when car would just stop.
I have been looking for help in my area with no luck.
Last night I went back to searching google and found the following -my car
(Mercedes 2000 ML320 ) information.
Please read and your advice: MY CAR IS DANGEROUS and NOT drivable to
Benz store over mim 50 miles away.
In a recall is it their responsibility to tow my car to them. I donít dare drive it to grocery store let alone on highway to anywhere
Every thing reported by others has happened to me..... everything.
https://repairpal.com/mercedes-benz-...SUE1a3JULVRpbw
Read comments by owners SCARY
https://repairpal.com/brake-light-sw...ing-lights-453
Thanks Iím sorry donít know 163-164 ?style
Wanda
wicked1 is offline
post #2 of 12 (permalink) Old 06-23-2019, 04:41 AM
Purple Moderator
Date registered: Jul 2005
Quoted: 1527 Post(s)
It is the brake light switch recall. It is still active.
I am not sure what their obligation is to tow it.
Noodles is offline
post #3 of 12 (permalink) Old 06-23-2019, 10:35 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 916 Post(s)
@hotcitykitty @wicked1
You have first reported this issue in 2014 under different user name.
https://www.benzworld.org/forums/w16...ml#post9035665
Witek_M is offline
post #4 of 12 (permalink) Old 06-23-2019, 11:35 AM
Date registered: Sep 2009
Vehicle: 2000 Mercedes ML55 AMG, 2006 Mercedes ML350
Quoted: 23 Post(s)
Im a little lost here. You say you replaced your stop light switch already but now your saying that you want it replaced under warranty and you want your vehicle towed to have it done? Just don't use your cruise control during the drive and drive it to the dealer. It's not going to accelerate itself because of a bad switch. It was accelerating because you had cruise on and there was no signal telling it to cut the cruise when you taped the brake.
I'm still confused from your post, but you said something about the car stopping itself when driving. Can't see that as being an issue from the brake switch. You need to invest in a scanner that can read all these codes and tell us what's actually happening.
Brettriehl101 is offline
post #5 of 12 (permalink) Old 06-24-2019, 01:29 AM Thread Starter
wicked1's Avatar
BASS light indicates has brake issues... And apparently Cruise Control. I only found out this 5 days ago
After every single attempt to fix BASS light malfunction I had the horrifying experience of my car not responding to braking while using CC. WHO KNEW ... not BenzWorld blog
The car spreed up all on its own when I tried to brake. 5 blocks at 80 mph
NOTHING
I was just wondering why on earth this issue had not been on file within this forum 3/5 yrs ago when I first started having the problem.
Only after MY CARís recent attempt at murdering me & other ppl that I googled every conceivable idea around the bass light issue and came up with the recall information.
I simply posted info bc ITS A MATTER OF LIFE & DEATH
I posted the recall notice because thought ppl should know... all my BASS issues have boiled down to all comments & problems made by other benz owners ( link provided)
I got incredibly lucky it was 3:30 AM & traffic was very low. Had this happened day time on that street/HWY ppl would have died.
wicked1 is offline
post #6 of 12 (permalink) Old 06-24-2019, 01:57 AM
mattml430's Avatar
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 807 Post(s)
BAS not Bass
Bass is loud music in Artís 55 and fresh water fish that taste a bit muddy.
BAS stands for Brake Assist System. It provides additional braking power in case of emergency situations. ESP stands for Electronic Stability Program. It helps as you drive by braking individual wheels or reduce engine torque output.
Your situation could of been prevented by turning off the cruise control at the stalk. Sounds like you may of panicked a little which is completely normal in that situation. Youíve probably tried braking to find it slowed a little but with lack of vacuum under acceleration the brakes wouldnít of felt as good as normal, then once you took your foot off the brake for a second it would of gone back into cruise control and accelerated. Your car is not possessed and trying to kill you. Just needs a brake light switch.
Noodles, art_arev and dramos like this.
mattml430 is offline
post #7 of 12 (permalink) Old 06-25-2019, 10:37 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 789 Post(s)
Send a message via Skype™ to art_arev
Matt,a bit of a correction.........
loud music in both 55's
mattml430 likes this.
Art
art_arev is offline
post #8 of 12 (permalink) Old 07-10-2019, 02:55 PM
Date registered: Jun 2014
Vehicle: 2000 ML320
Quoted: 4 Post(s)
Hello, please try to have some patience here. Yes I have BASS ESP issues in 2014/15
And fix the problem. Now 2019 same repair, but BASS LIGHT is only light on.
new issues have occurred with this light on now.
Car just stops ( Engine ) C control going nuts ~hard start~ won’t start up after engine
dying on road. I of course do NOT Engage cruise control while bass engage
while Bass issue light is on.
up that make it difficult to just run to a MB dealership 3 hr away. Car dies after runs
for a bit . 5 -15 minutes.
All I was asking (recently) Has anyone had these issues w/BASS LIGHT ON. Finding the comments
about Bass recall info, see above jpeg many ppl had these very issues but no place to discuss
the Bass light issues. MB says they are not connected. I don’t believe that. They minimized my speeding experience.
I thought I might fine more thoughts on stated crazy shit that’s happening in BW forum.
Car was running fine prior to latest light unresolved issue.
I realize NOW owning a Mercedes-Benz in a small town (compared to Vegas) is probably a
very bad idea but at the time it was the only decent running car I could find for the price.
Ppl tend to beat the hell out off cars here.
I’m not talking from ignorance, I sold Fords here for 3 yrs. most trade in were total crap unless
in the $8-$10 k area. I had $4500
Believe me there won’t be a second MB.
Absolutely unimpressed with Mercedes-Benz customer service
So, thank you for your help & comments
hotcitykitty is offline
post #9 of 12 (permalink) Old 07-10-2019, 03:43 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 305 Post(s)
Please, could some other member interpret / decypher the contents here.
Respectfully, I tried using google translation to no avail.
khomer2 is offline
post #10 of 12 (permalink) Old 07-10-2019, 08:05 PM
mattml430's Avatar
Quoted: 807 Post(s)
I think it means they have a bad crank sensor and BAS issue still. A little hard to interpret.
khomer2 likes this.
