ML430 replace serpentine belt tensioner pulley? - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 06-17-2019, 08:57 PM Thread Starter
Date registered: Dec 2011
Vehicle: 2000 ML 430. 2007 Landrover D3 3.9L. 1976 Bristol 411
Quoted: 27 Post(s)
Hi all,
The serpentine belt tensioner pulley bearing on my ML disintegrated last night while I was driving the car. Fortunately it happened at a set of traffic lights and I was able to pull over to the side of the road pretty much immediately.
Can I just replace the tensioner pulley or do I have to have to replace the whole tensioner unit?
nivekau is offline
post #2 of 26 (permalink) Old 06-17-2019, 09:33 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 265 Post(s)
Are you asking.... bearing replacement in the tensioner pulley vs. tensioner unit replacement?
Correct me if I'm wrong, It seems like the Q you are asking is one in the same.
khomer2 is offline
post #3 of 26 (permalink) Old 06-17-2019, 09:46 PM Thread Starter
Quoted: 27 Post(s)
What I meant was is it okay to just replace the tensioner pulley (which includes the bearing).
It appears that the pulley can be bought on its own, so I guess I don't have to change the whole tensioner unit :-)
khomer2 likes this.
nivekau is offline
post #4 of 26 (permalink) Old 06-17-2019, 09:49 PM
260e crusier's Avatar
Date registered: Nov 2010
Vehicle: 1999 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
Quoted: 490 Post(s)
You can just replace the pulley and bearing assembly only if you want.
Personally, I would replaced the the whole tensioner, idler pulley and serpentine belt. It's a relatively cheap and easy DIY even with OEM parts.
260e crusier is offline
post #5 of 26 (permalink) Old 06-17-2019, 10:01 PM Thread Starter
Quoted: 27 Post(s)
I will do, however to get the parts at a reasonable price I need to order them, and in the meantime I intend to do a quick roadside repair so I can get the car home. I could have got the parts today but they would cost more than double what I can buy them for online.
nivekau is offline
post #6 of 26 (permalink) Old 06-17-2019, 11:16 PM
partnumber187's Avatar
Date registered: Jun 2016
Vehicle: Mercedes-Benz
Quoted: 251 Post(s)
Tensioner may very possibly fail in short order. Might not be problematic at the moment, but they don't like being disturbed. Have seen more than a few times an operable tensioner fail after pulling a serp belt.
Matter fact, just happened to me about a month ago. Belt was nice and tight, no squeaks. Decided to upgrade alternator while I was doing common oil seal leak repairs and when I reinstalled the damn thing was chirping and wobbling.
Proceed with caution. >>>
#dontdealwithkahlil
partnumber187 is offline
post #7 of 26 (permalink) Old 06-19-2019, 12:28 PM
Date registered: Sep 2015
Vehicle: 2001 ML430 230K Miles
Quoted: 16 Post(s)
Get the Gates version on Amazon. It is the Litens part in a Gates box for $76!
Sent from my VS988 using Tapatalk
Carl Burr is offline
post #8 of 26 (permalink) Old 06-19-2019, 06:31 PM Thread Starter
Quoted: 27 Post(s)
Carl, if I was in the US I would, but Amazon in Australia don't have it.
I managed to get a pulley late yesterday and had the car brought home. I have fitted the pulley (the tensioner *feels* fine at the moment), but I just can't get the belt back on! It's driving me crazy.
nivekau is offline
post #9 of 26 (permalink) Old 06-19-2019, 06:53 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 883 Post(s)
You need to compress tensioner by turning it counter clockwise and arresting it in place with 4 mm pin. Route the belt around all pulleys leaving water pump pulley as last.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 26 (permalink) Old 06-19-2019, 07:47 PM
Quoted: 490 Post(s)
$68.22 at one of my "go to" place.....
https://www.rmeuropean.com/Make/Part...rch=1122000970
