P0410 Diverter valve removal - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-14-2019, 12:23 PM Thread Starter
dramos's Avatar
Date registered: Dec 2015
Vehicle: 2000 ML320 LHD
Quoted: 146 Post(s)
Send a message via Yahoo to dramos
I have attempted to remove the diverter valves as a step in curing my P0410 problem several times with no luck.
Tried squatting on the engine, pull & rotate out after getting the hood away...all to no avail.
Feels like I'm trying to push a train to start. Lolz
Maybe there's a technique to it that I don't know.
I need guidance & instruction. Pls! Anyone.
I live life like the whole planet depends on me
dramos is online now
post #2 of 8 (permalink) Old 06-15-2019, 03:01 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1548 Post(s)
Do you mean the Shut-off Valves?
Code Po410 refers to the AIR Pump voltage problem and or its relay K28.
First try swapping K28 with blower motor relay.
Name:	AIR Shut-off Valve.jpg
ID:	2520380   Click image for larger version
Name:	K28 Relay.jpg
43sqd is offline
post #3 of 8 (permalink) Old 06-15-2019, 04:16 AM Thread Starter
dramos's Avatar
Quoted: 146 Post(s)
Thanks for the correction Jim. Guess diverter valve is the other name for the Shut-off valve.
I had P0442 & P0410.
Was able to fabricate my own smoke machine & accidentally discovered a rotten hose by the driver wheel well while changing my steering rack(see attachment) with Art's help.
So, after changing that hose the P0442 didn't return.
I have tried the relay swap with no luck.
Now there are multiple cylinders 1 & 2 misfires & P0410 with shakiness. Drama hasn't been driven much for a while now due to work.
I intend to check plugs, coils & cables when I get back to it.
Need all the guide to tackle all the problems head on.
post #4 of 8 (permalink) Old 06-15-2019, 04:41 AM
dramos, read the prerequisites in the first PDF that I supplied, and tell me what noticeably jumps out ?
43sqd is offline
post #5 of 8 (permalink) Old 06-15-2019, 05:00 AM Thread Starter
dramos's Avatar
Quoted: 146 Post(s)
Okay so, I see that all my other codes are responsible for the P0410 code.
Without those prerequisites coming out fine the P0410 code & CEL will trigger on.
So I have to do the spark plugs, coils & cable checks at Cylinders 1 & 2 then that most likely cures the P0410 code.
Hope I got the point Jim?
post #6 of 8 (permalink) Old 06-15-2019, 05:18 AM
You got the point. Why don't you just give DRAMA a nice burial?
mattml430 likes this.
43sqd is offline
post #7 of 8 (permalink) Old 06-15-2019, 05:29 AM Thread Starter
dramos's Avatar
Quoted: 146 Post(s)
Lolz
Jim, even though she's only got a flu & not a life threatening illness I can burry her alive if......
You sell me your 02 ML320. I will also invite you for the burial.
Deal or no deal?
post #8 of 8 (permalink) Old 06-15-2019, 05:33 AM
No deal.
mattml430 and WE47B1ME like this.
43sqd is offline
