[2003 ML500] Antenna, Drivers seat side plastic, 3rd window screw - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-12-2019, 10:24 AM Thread Starter
Date registered: Jun 2019
Vehicle: 2003 Mercedes ML500
A post helped me out awhile back regarding the auxiliary water pump and providing alternatives at a fraction of the cost. I need advice on alternatives or model numbers of parts so I can get them replaced. any help would be great.
Antenna on the top of the vehicle became brittle and broke off. I believe I found the model number "1638201575". Are there any alternatives?
Drivers seat side plastic the control panel on the side of the drivers seat. the plastic is cracked and wont stay on, controls work fine. I cannot find a model number. would consider replacing the whole seat as the leather has ripped but that depends on costs.
3rd window screw became brittle and broke off (drivers side). The 3rd window, I think is what it is called, the far back window. the window opens fine but arm is not bolted to the glass. all these bolt caps feels brittle on both sides. I'm am told I need a whole unit as they dont sell just the bolt caps. any advice here would be great
Thanks in advance
psllaw3601 is offline
post #2 of 7 (permalink) Old 06-12-2019, 10:52 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 218 Post(s)
Thanks in advance
Welcome psllaw3601,
Antenna is for GPS. Do you have that feature built-in? Alternatives? TO reply to your question, have looked on fleabay?
DS plastic side panel cover - NLA from stealership but you may want to verify. Note: $$$$$ if they have the correct color for you.
Best to check out the pickn pull or car-parts.com This side cover is notorious for breaking/splitting when moving in and out, etc.
https://www.benzworld.org/forums/w16...coverings.html
3rd window screw - an option to purchasing a complete unit - https://www.benzworld.org/forums/w16...-hardware.html
Try using the search button (top right hand side of the forum page) It's very resourceful.
Name:	search benzworld - it's your best friend.png
khomer2 is offline
post #3 of 7 (permalink) Old 06-12-2019, 11:29 AM Thread Starter
Originally Posted by khomer2 View Post
Welcome psllaw3601,
1) That Antenna is only for GPS? hmmm then I will just super glue it back on for aesthetics and figure out why the radio doesnt work.
2) This part I will have to look for. Do you know a model number, the site you gave doesnt say it. or what is it commonly refereed to as?
3) The post you directed me to made reference to another site which said the part number is 1636720001. They dont indicate what car its for, should I assume this is the correct part?
Thank you, I spent a few hours searching and you helped alot
post #4 of 7 (permalink) Old 06-12-2019, 11:49 AM
WE47B1ME's Avatar
Date registered: Sep 2014
Vehicle: 2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
Quoted: 212 Post(s)
Roof fin is teleaid and GPS -- extinct systems. Glue it.
psllaw3601 likes this.
WE47B1ME is offline
post #5 of 7 (permalink) Old 06-12-2019, 11:58 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 823 Post(s)
Rear vent window parts. https://nemigaparts.com/cat_spares/e...75/06h/67/045/
Seat base covering. https://nemigaparts.com/cat_spares/e...75/06h/91/180/
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 7 (permalink) Old 06-12-2019, 12:15 PM Thread Starter
Originally Posted by Witek_M View Post
Perfect! thank you
post #7 of 7 (permalink) Old 06-12-2019, 12:48 PM
khomer2's Avatar
Quoted: 218 Post(s)
Attached.
This should move you in the right direction.
For the radio, I presume you checked your fuses? Is there power to the radio?
Name:	Screen Shot 2019-06-12 at 12.39.39 PM.png
ID:	2519802   Click image for larger version
Name:	Screen Shot 2019-06-12 at 12.40.04 PM.png
ID:	2519804   Click image for larger version
Name:	Screen Shot 2019-06-12 at 12.43.11 PM.png
ID:	2519806   Click image for larger version
Name:	Screen Shot 2019-06-12 at 12.43.23 PM.png
khomer2 is offline
