BAS/ESP electrical gremlins - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-11-2019, 11:55 PM Thread Starter
Date registered: May 2019
Vehicle: 2000 ML320
My friend got a cheap ML320 with a burned exhaust valve, but at the time it had no electric/electronic problems. We swapped the engine with a lower mileage junkyard pull, and have had all kinds of electrical problems since. The car won't start in park, but will in neutral (mechanic traced it back and said the ECM thinks the car is in R when it's actually in P). It starts in N, so I'm not going to sweat this one for now. However, once we figured out it would start in N, now there are other faults. I picked up an iCarsoft MBII to read/reset DTCs, and here's the deal.
The BAS/ESP light is on, and the codes I get from the ESP are C1200 (Brake light switch S9/1) and P120008 (unknown.) I clear the codes, and the instant I press the brake pedal, the codes come back. Also, the brake lights do not come on. I replaced the BLS, no change. I tried disconnecting the rear lights, no change. I did not disconnect the third brake light, if there is one.
From the BAS computer, the code is C1025 (CAN signals.) When I clear that it comes back quickly.
There is probably more relevant information, but it's late and I'm pretty tired.
Thanks for any help you can provide in tracking this down.
JulianH is offline
post #2 of 9 (permalink) Old 06-12-2019, 03:49 AM
LWB250's Avatar
Date registered: Jan 2013
Vehicle: 65 220SEb, 97 SL500, 98 E320 Wagon, 2002 ML500 - former W108/W112/W114/W123/W124/W126/W140/W220
Quoted: 1046 Post(s)
Brake light switch is a known issue. Replace it. Under $20 from the dealer.
LWB250 is offline
post #3 of 9 (permalink) Old 06-12-2019, 06:19 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 835 Post(s)
For no start in P check transmission shifter linkage. Most likely got out of wack during engine swap
https://www.benzworld.org/forums/w16...ission+linkage
Brake light switch is evaluated against booster travel sensor. NO and NC contacts must toggle. Look at live data in traction systems module.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 9 (permalink) Old 06-12-2019, 02:30 PM Thread Starter
Vehicle: 2000 ML320
I've already replaced the brake light switch. Here's what the live data stream shows:
When first turning the key to the on position, brake not depressed:
Stop lamp switch NO contact - OFF
Release switch NO contact - OFF
Release switch NC contact - ON
Depress brake:
Stop lamp switch NO contact - ON
Release switch NO contact - ON
Release switch NC contact - OFF
Release brake:
JulianH is offline
post #5 of 9 (permalink) Old 06-12-2019, 09:33 PM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 781 Post(s)
Send a message via Skype™ to art_arev
Have you just changed the engine using your original harness? Or have you used the new engine harness from the donor car? If you have used the donor engine harness, which year ML was it from?
Art
art_arev is offline
post #6 of 9 (permalink) Old 06-12-2019, 09:35 PM Thread Starter
Vehicle: 2000 ML320
Interesting question. I used the harness from the donor, a 99.
JulianH is offline
post #7 of 9 (permalink) Old 06-13-2019, 01:33 AM
art_arev's Avatar
Quoted: 781 Post(s)
I don't know your friends ML year, but that could be your problem.
Art
art_arev is offline
post #8 of 9 (permalink) Old 06-13-2019, 07:47 AM Thread Starter
Vehicle: 2000 ML320
It's a 2000, any idea what could have changed?
JulianH is offline
post #9 of 9 (permalink) Old 06-13-2019, 11:23 AM
art_arev's Avatar
Quoted: 781 Post(s)
A lot of things. A 1999 harness will not work correctly on a 2000. Wiring is different. You should have used your original harness.
Art
art_arev is offline
