Replacing clutch fan with electric? - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 06-08-2019, 11:55 AM Thread Starter
Date registered: Jul 2012
Vehicle: 2000 ML320
Quoted: 34 Post(s)
Has anyone retrofit an electric ML55 style fan to replace the clutch fan? Wondering if it's worth it and if it would yield a few more MPGs?
https://www.amazon.com/1635000293-Ra...s%2C189&sr=8-3
LegendaryATM is offline
post #2 of 14 (permalink) Old 06-08-2019, 12:08 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 266 Post(s)
You dont have this on your '00 ML55?
And who ever purchased a ML55 for mileage savings?....
I dont see why it wont work.
This is on our ML500 AND
the link also says "For Mercedes ML55 AMG 2000-2003"
Contact the seller to confirm.
khomer2 is online now
post #3 of 14 (permalink) Old 06-08-2019, 12:16 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 883 Post(s)
If you need more MPGs get lighter pair of shoes.
In ML500/55 fan is controlled by engine temperature and refrigerant pressure/temperature map. You would need to develop controller that can simulate that. Then there is reliability factor. Fan clutches almost never fail from one second to the next. Electric things do.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 14 (permalink) Old 06-10-2019, 02:26 PM
Date registered: Nov 2014
Vehicle: 2000 E 320 Wagon + 2002 ML 500 SUV
Quoted: 141 Post(s)
I have a hard time imagining it would help that much.
Do you think your current mechanical fan clutch is working properly ?
Our ML500 already has the electric fan you're referencing, and MPG is still so-so.
What is your MPG now ?
This looks like a reproduction aftermarket part. If it works well, that's a pretty good price.
I think they're 2 to 2.5x that for the stock part, if memory serves.
I've learned that the V-8 ML's are just a hungry beast. That goes double if you are doing lots of stop & go or mixed highway miles.
The only time I've said: "Wow, pretty good MPG !" was on long road trips at steady state speed...just sayin !
Cheers - David
Gone, and fondly remembered:
1975 240D - 4 speed manual, power nothing
1984 190E 2.3 - Cute, reliable & slow
1983 300SD - Great highway tourer, 28mpg
Here & greatly appreciated:
2000 E 320 Wagon -
2002 ML 500 - Finally got one !
2000 E 320 White Wagon is online now
post #5 of 14 (permalink) Old 06-11-2019, 09:51 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 785 Post(s)
Send a message via Skype™ to art_arev
Originally Posted by 2000 E 320 White Wagon View Post
I've learned that the V-8 ML's are just a hungry beast. Cheers - David
Compare them to any other V8 and you will see they are not hungry at all...................
Noodles likes this.
Art
art_arev is online now
post #6 of 14 (permalink) Old 06-11-2019, 10:18 AM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
Simply dropping highway speed from 80mph to 70mph improves mileage 10%. Dropping to 65 gains another 10%.
https://www.mpgforspeed.com/
khomer2 likes this.
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #7 of 14 (permalink) Old 06-11-2019, 10:26 AM
khomer2's Avatar
Quoted: 266 Post(s)
Lol- I dont even care to fathom what our E50 eats. Just fill n go. Never got this for it's mileage credentials.
Im happy with the ML. It's an obedient Beast.
Noodles and art_arev like this.
post #8 of 14 (permalink) Old 06-12-2019, 07:04 PM
Quoted: 141 Post(s)
Ok a thought just occurred.
Agreed that Witek said difficulty would be controlling fan per the MB scheme.
Q: If you now have mechanical fan that works by a heat sensitive viscous clutch then its now totally "analog", right ?
If this is so, you should be free to add in an acessory fan that fits ML radiator & can move enough air and use a simple temperature probe with preset on / off points & HD relay.
Here is a fan that is really close in size to ML radiator at 24"w x 19"h Fan & shroud, 3000 cfm - original application for Ford / Mercury V-8 4.7 litre.
Below is also simple relay & temp probe controller.
Only concern might be to coordinate temp with engine thermostat.
Some guys use these in place of mech fan on Dodge Ram 5.9 Cummins fan conversion.
If it will cool the mighty Cummins, the M-112 or M-113 should be no issue.
Having trouble posting link.
Its Dorman Electric Fan 620-118.
@ www.amazon.com for $78...
Cheers - David
2000 E 320 Wagon -
post #9 of 14 (permalink) Old 06-12-2019, 07:24 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 883 Post(s)
Cheers - David
Your scenario covers only engine temperature. What about ac?
105 F outside, 5 pm, engine cold after all day at work. Ac on high, refrigerant pressure @450 psi, compressor turns off for safety. Sweat running down your balls.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 14 (permalink) Old 06-13-2019, 08:31 AM
Quoted: 141 Post(s)
Right on Art.
This relay / temp probe kit has a terminal for A/C compressor to turn on fan - shouldn't be a problem right ?
https://www.amazon.com/gp/aw/d/B001S...KIKX0DER&psc=1
Dorman 620-118
Powerful V-8 electric fan
3000 cfm
https://www.amazon.com/gp/aw/d/B07F6...018EBU1K&psc=1
Simple electric fan thermostat relay controller
2000 E 320 Wagon -
