Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   W163 M-Class (https://www.benzworld.org/forums/w163-m-class/)
-   -   Tricky ML430 limp mode (wrong front axle speed) (https://www.benzworld.org/forums/w163-m-class/3027630-tricky-ml430-limp-mode-wrong-front.html)
stalje 05-29-2019 11:56 AM
3 Attachment(s)
Hello everyone,
I'm sorry to open yet another thread about some kind of ABS/BAS TCS etc... issue.
But this one may be different, since I was not able to find any other that was similar.
Let's begin with the context :
I bought this ML already in limp mode. The owner had bought an ML55 AMG and was not interested anymore in fixing this ML430.
Symptoms :
When I turn on ignition, I hear several beeps coming from the binnacle. Then I start the engine and here are the lights that remains illuminated :
https://www.benzworld.org/forums/att...516708&thumb=1
In this situation, the gearbox is stuck in 2nd gear. The engine itselft work as it should. I'm able to reach 75km/h then the car slow down itself to keep under this speed (ignition shut I guess).
Of course, I'm unable to use sequential gear selection and the low range can't be engaged.The speedometer remains accurate.
I borowed a Delphi diagnosis tool and was able to find interesting data :
Engine section is showing a p1605 fault :
https://www.benzworld.org/forums/att...516710&thumb=1
I saw another description of this fault mentionning incoherent wheel speeds (that's important)
Before, I also had a fault about gearbox selector miscomunicating but I replaced the conductor plate and the plug, and I don't show up anymore.
If I go the the data list of the engine section, I can reach #49 and this is the front axle speed : this one remains at zero whatever the real speed is. #50 is about the rear axle speed and this one is accurate.
That was for the engine section.
Now, if I go to Instruments section, I have no faults stored, but additionnal information about each wheel speed :
https://www.benzworld.org/forums/att...516712&thumb=1
So, that's explaining why I obtained the speed I mentionned before : the front wheels sensors are always reading this value : 32768 Rpm
The rear speed sensors are accurate.
Both speed sensors are new and I tested wire continuity from the plugs to the ESP module : everything is in order.
I have to mention I also have a ML320 that is working perfectly. I took its ESP module and installed in the 430 : same phenomenon.
I also replaced the ABS motor controller and no change. I tested the ABS motor itself by shortwiring the replay and it works perfecly.
The only way to display 0 RPM the the front wheels is to unplug the ESP module...
So... here I am. In a CUL DE SAC.
I would be really thankful if you could try helping me sorting this out... I have no idea what to do now.
Btw, sorry for the potential horrendous mistake I can make while writing... I'm not too familiar when english.
Cheers!
DrX 05-29-2019 02:30 PM
I think you need to buy/borrow a pro level scanner that can read and clear codes in the ETC module. The popular model on this forum is the Autel MD802 All Systems.
Then post the 3-digit code/s from the ETC module.
stalje 05-29-2019 11:51 PM
isn't that just what I already have ?
Do you think that the device you mention can really go further ?
Witek_M 05-30-2019 05:23 AM
Have you tried connecting that scan tool to your working ML320 to see what speed values are displayed?
Why is SRS light on?
stalje 05-30-2019 06:30 AM
Yes, on the ML all the info are coherent. 0 rpm and 0km/h when idling and increasing when rolling.
The SRS light is on for another fault that I have deleted since that.
stalje 05-30-2019 06:32 AM
ml320*
DrX 05-31-2019 03:14 AM
I donít think so. If it was, you would have the 3-digit ETC codes, and have escaped limp mode.
Yes. Clear the codes in the ETC and ECM, drive the car out of limp mode, and if/when it goes back, read the codes from both modules and the ESP/BAS control module and post them here.
stalje 06-04-2019 08:58 AM
Thanks for the advice, I'll think about buying this tool, so.
stalje 06-15-2019 02:29 AM
I bought the diag tool you adviced me. And it seems to be quite complete thank you.
Here are the specific codes that I read from the ml430 !
C1100 : Unkown
C1101 : Unkown
C1140 : Unkown
C1025-008 : Fault in CAN communication with control unit N47-7 (ABS control module). If no customer complaint exists, the fault can be erased
They are all the fault that come back immediatly after an erase.
Hope they (and you : ) ) will help finding me where is the issue on the car...
DrX 06-15-2019 02:53 AM
Youíre welcome.
Did you get it out of limp mode?
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
