Need help with my Remote FOB - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 05-19-2019, 05:47 PM Thread Starter
Date registered: Jan 2012
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Hey all,
Replaced my 2 batteries in the key fob. A little history, the remote stopped working last year, but decided to try and get it working. I've checked all fuses in both the engine compartment and passenger side panel, all good. I am just not sure what relay or fuse controls the remote receiver.
I did go to a key shop to verify my remote was sending an IR signal, which it does. I've tried all the youtube videos on re-syncing the remote. Nothing works.
I'm stuck and not sure what to do next. I did call the MB Dealer and they want $190 to diagnose. I am hoping someone here has actually had a similar issue and fixed theirs so I can avoid the dealer.
Leo
MPDano is offline
post #2 of 14 (permalink) Old 05-19-2019, 11:39 PM
noetico's Avatar
Date registered: Feb 2015
Vehicle: 2002 Mercedes ML320, Mercedes 190E 2.3L (sold), 2001 Mercedes c320(gone)
Quoted: 220 Post(s)
I'm up against the same issue haha... Underside of the fuse no cover you will find the fuse assignments, if the lock/unlock button on the lower console works then the fuse should e fine.
I am considering some other arrangement that allows me even a worse case scenario have a hidden/secret outside button I can use to lock and unlock, just need it once in a while.
Kent
noetico is offline
post #3 of 14 (permalink) Old 05-20-2019, 05:12 AM Thread Starter
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Yes, inside door lock/unlock works fine. I believe the fuse is #42 and the relay is just above it, both for the central locking mechanism. I do notice the fuse has no power on it even when changing it with a new one. There was a mouse nest in my fuse box that I cleaned up.
MPDano is offline
post #4 of 14 (permalink) Old 05-21-2019, 07:11 AM Thread Starter
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Can someone check their fuse #42 in their fuse box under the hood? I need to verify if it's 12v positive. Mine is grounded as I feel it might be due to the mouse nest that was in there.
MPDano is offline
post #5 of 14 (permalink) Old 05-21-2019, 07:45 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 834 Post(s)
Fuse #42 is gounded by relay K20 lock all. Only time you will see 12 V is during short burst lock all.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 14 (permalink) Old 05-21-2019, 07:54 AM Thread Starter
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Perfect, thanks for that. Saves me pulling out that fuse box. Still need a working remote if anyone has any suggestions to try.
MPDano is offline
post #7 of 14 (permalink) Old 05-21-2019, 08:34 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 834 Post(s)
Pull up the fuse box to make sure antenna lead to AAM is not damaged. Remote locks operate trough RF not IR.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 14 (permalink) Old 05-21-2019, 10:39 AM Thread Starter
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Will do. Is there any pictures of this area?
MPDano is offline
post #9 of 14 (permalink) Old 05-21-2019, 12:07 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 834 Post(s)
https://www.benzworld.org/forums/w16...ht=aam+antenna
https://www.benzworld.org/forums/w16...ml#post9816393
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 14 (permalink) Old 05-21-2019, 12:30 PM Thread Starter
Vehicle: 2005 ML350
Quoted: 12 Post(s)
Ok, just removing the cover on behind the fuse box and not lifting the fuse box itself?
The antenna is coax cable? Where does the end of the coax end up?
Also, testing procedure on the antenna?
MPDano is offline
Has anyone ever fixed a faulty remote fob? (Not AAM) Jetpilot718 W163 M-Class 5 04-10-2015 08:31 AM
How to change battery in remote key fob OAKESY 320 C208/A208 CLK-Class 5 02-03-2014 02:28 PM
Key Fob Remote not working. Chris A R170 SLK-Class 8 06-16-2011 01:43 AM
possible solution for remote fob davefinger W163 M-Class 4 11-30-2008 03:24 PM
96E320 remote fob problems Lynall W210 E-Class 2 08-15-2006 05:03 AM
