Hitch ball mount drop - how do I get to 18.5" - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-15-2019, 09:58 AM Thread Starter
Date registered: Jan 2013
Vehicle: Ex 97 S202 C200 + 02 W163 ML320 + 05 A209 CLK500 + 2011 B8 S4
Quoted: 14 Post(s)
Hi,
About to install the OEM hitch on my ML320.
Planning to tow a car on a uhaul "Auto Transport" trailer and they said for level height the top of the ball should be at 18.5".
Any idea how much of a drop / lift I need in order to get there?
Thanks!!
Patrick
DarkRothaus is offline
post #2 of 5 (permalink) Old 05-15-2019, 12:49 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 767 Post(s)
If its the removable hitch it can be turned to make different heights. You do need to remove the ball though. A couple of inch either way will be ok. Your better to have the nose of the trailer pointing down a little than up.
mattml430 is online now
post #3 of 5 (permalink) Old 05-15-2019, 01:10 PM Thread Starter
Quoted: 14 Post(s)
Thanks!
So would it be a good idea to get a two inch drop and see which way it fits better? (Two inch seems most popular based on number of Amazon reviews )
Or a four inch?!
post #4 of 5 (permalink) Old 05-15-2019, 01:16 PM
mattml430's Avatar
Quoted: 767 Post(s)
Generally a standard tow ball height is 450-500 mm in our language so a 2 drop will put it to low. It will depend completely on the ride height of your car. You really need to install it and see where it sits. If your ride height is standard I would stick with a standard hitch.
post #5 of 5 (permalink) Old 05-15-2019, 09:40 PM Thread Starter
Quoted: 14 Post(s)
Got it. Totally didn't occur to me that simply straight might be the way to go.
I'm new to those hitches, classes, drops etc. - used to the German / European ones that don't really have any of that. But then.. you also don't see too many lifted trucks out there that would require them
S430 S500 Engine Mount Replacement DIY zz4x4 W220 S-Class 25 08-12-2018 01:38 PM
Trailer hitch install on my 1985 300TD. (Pictures) Rockyriver W123 E,CE,D,CD,TD,TE Class 12 04-25-2016 11:58 AM
Towing: What kind of ball mount do U use ? billjet W164 M-Class 7 02-20-2008 06:57 PM
OT: Where did you get your tool for R+R of subframe bushings... to loss W123 E,CE,D,CD,TD,TE Class 6 12-27-2007 10:54 AM
The World's Largest Ball of Tape Is Up For Auction on Ebay none123321 Off-Topic 2 04-17-2005 03:53 AM
