1999 ML320 front end locks up. Help?!?! - Mercedes-Benz Forum
post #1 of 32 (permalink) Old 05-04-2019, 07:42 PM Thread Starter
Benzmebenzyoudont's Avatar
Date registered: May 2019
Vehicle: 1999 ML320, 2003 ML350, 1976 280C, 1995 S500
Quoted: 11 Post(s)
Hi everyone. New to the forum. I bought my ML for 500. Thinking it was a good deal. Thre lady who owned it before had it for 19 years. She said that her mechanic quoted her 1500 to fix and was letting it go so cheap because it didn't run.
The engine starts and it engages all gears. So it had nothing to do with the engine or transmission (i think). Anyway, when i first got it, all 3 lights were on the dash (esp, bas, brake) thinking those were thr issue, i changed thr yaw, lateral and brake switch/sensors. All lights disappeared.
When you try to drive the car, it feels like the car wants to lock brakes at least the front driver. Sometimes it feels likes both front try to lock.
I tried driving it and it locked up and forced a stop. It does it on reverse but doesn't force me to stop. I can hear it grinding around.
One thing to note, i cannot push the car on neutral. The car is totally locked in neutral too.
I disconnected the ABS unit and the ESP fuses. And it still does it. (Does it have a secondary ABS or ESP comp?)
I changed out the front driver axel because the boot was busted. I also changed out the front diff thinking that was the issue and it still does it. I could have bad luck and picked a bad one from the yard.
I have a reg ODB reader and no codes are showing. No lights on the dash on.
I am gunna attach videos. Let me know what you guys think is going on. Thank you!!
https://youtu.be/poRFZCg17mc
Benzmebenzyoudont is offline
post #2 of 32 (permalink) Old 05-04-2019, 07:47 PM Thread Starter
Quoted: 11 Post(s)
Here's another video.
https://youtu.be/RtNsQQsLOI0
post #3 of 32 (permalink) Old 05-05-2019, 02:13 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 790 Post(s)
Sounds to me like your transfer case is shot.
mattml430 is offline
post #4 of 32 (permalink) Old 05-05-2019, 12:09 PM
Date registered: Mar 2019
Vehicle: 2003 ml500, 2004 ml350
Quoted: 43 Post(s)
Fill out your profile to include location and vechicle. For example I know where two pick a part mls are. But if I have no idea of where you are in relation to me. With a location a member may let you in on one they spotted.
If my memory is correct early mls had a 50:50 ratio newer a 50:48. There were problems with the 50:50. Don’t know if you can swap with a 50:48 should you indeed have the 50:50?
wallyo is online now
post #5 of 32 (permalink) Old 05-05-2019, 08:27 PM
rudeney's Avatar
Date registered: Dec 2004
Quoted: 1688 Post(s)
You also need to get a scanner that can read codes form all systems. I hear good things about the Autel MD802 Elite.
- RODNEY
My Stable:
rudeney is offline
post #6 of 32 (permalink) Old 05-05-2019, 11:40 PM Thread Starter
Quoted: 11 Post(s)
I tried to update my location. But it doesn't let me? Maybe bc I'm on my phone? Anyway. Im in California with zip 92701. There are some MLs in the narby lkqs. So i picked up a front differential for it and still does this. The differential i replaced, did the same thing. Makes me feel like its something else. I was leaning to a bad transfer case
Even if i get another reader, there are no codes for a bad transfer case right?
Thanks for all the input.
I have a 1999 ML320 which makes it a w163.
post #7 of 32 (permalink) Old 05-06-2019, 02:42 AM
mattml430's Avatar
Quoted: 790 Post(s)
Disconnect the front driver shaft from the transfer case and spin the wheels by hand on full lock. If it still does it it’s most likely to be your front axles.
post #8 of 32 (permalink) Old 05-06-2019, 11:50 PM Thread Starter
Quoted: 11 Post(s)
When you say on full lock what do you mean? How do i lock them? Also i did change out the drivers side axle and the front differential. It Is doing the same thing with this differential and the old one.
post #9 of 32 (permalink) Old 05-06-2019, 11:51 PM Thread Starter
Quoted: 11 Post(s)
I ordered one from Amazon. Waiting for it to arrive. Should be here tomorrow.
post #10 of 32 (permalink) Old 05-07-2019, 01:22 AM
mattml430's Avatar
Quoted: 790 Post(s)
Just the steering on full lock.
Have you disconnected the front drive shaft off the transfer case.
Adjustable front camber/caster bolts install 1999 W210 bbirdwell W210 E-Class 17 05-21-2018 11:05 PM
1999 S600 Vin markcedes W140 S-Class 152 01-26-2018 09:03 AM
84 500sel front end alignment AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 3 05-11-2007 08:53 PM
Suspension and Handling guide - late Carroll Smith Bazzle R170 SLK-Class 3 06-20-2006 07:29 AM
Repair bolts for front end alignment on 1999 E430 Sport? RSIESQ The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 03-06-2005 08:46 AM
