Just another fuel level sensor problem - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-04-2019, 08:27 AM Thread Starter
noetico's Avatar
Date registered: Feb 2015
Vehicle: 2002 Mercedes ML320, Mercedes 190E 2.3L (sold), 2001 Mercedes c320(gone)
Quoted: 220 Post(s)
So recently I've been facing the fuel level sensor issue.
Background story:
The fuel pump assembly was bad, as per broken parts but the level sensor worked ok, although sometimes readings may delay until I'm idling on an incline and move again.
I changed it for some after market one; sadly no oem used unit and expensive to import one at this time.
The fuel level sensor looks ok, doesn't look off at all but fuel level wouldn't hold.
What I've tried:
1. The famous fuse reset of the ICM: on doing this, meter jumps to the level and over a short time, under 30minutes, falls back to 0.
2. Control module software reload with hhtwin in DAS. This seemed to work for a few days but then all things went back to the usual.
What I think is the real issue is: the control module is not really clearing the error: fuel level sensor short circuit to positive, open circuit. If you clear and read it's again there instantly, on ignition on.
To read level I use my Autel md802 to clear the error, as I clear it reads to the level detected and then over about 30 minutes will drop off to 0, the Amber low fuel light doesn't illuminate *edit* but will occasionally flash for a few seconds at random even when the level is very high after a reset of the fuse or by the scanner.
I've looked at other posts, is there any solution for this? This one is stubborn.
Kent
noetico is offline
post #2 of 6 (permalink) Old 05-04-2019, 10:13 AM
art_arev's Avatar
Date registered: May 2013
Vehicle: ML55 AMG 2003 RHD, ML55 AMG 2002 RHD
Quoted: 781 Post(s)
Send a message via Skype™ to art_arev
With SDS/HHTWin change the setting from normal to actual value. If that also doesn't work, then the sensor is cooked
Witek_M and noetico like this.
Art
art_arev is offline
post #3 of 6 (permalink) Old 05-04-2019, 12:23 PM Thread Starter
noetico's Avatar
Quoted: 220 Post(s)
Thanks a lot! That would be under the codings for the module right?
Thank you, I would give it a go on the morning and update.
Kent
noetico is offline
post #4 of 6 (permalink) Old 05-04-2019, 02:30 PM
art_arev's Avatar
Quoted: 781 Post(s)
Yes. Under Instrument Cluster
Art
art_arev is offline
post #5 of 6 (permalink) Old 05-04-2019, 02:53 PM Thread Starter
noetico's Avatar
Quoted: 220 Post(s)
Thanks!
Kent
noetico is offline
post #6 of 6 (permalink) Old 05-20-2019, 09:57 AM Thread Starter
noetico's Avatar
Quoted: 220 Post(s)
Ok so unfortunately the cable for my star system is misbehaving so I've been unable to perform the check art asked for. But here's some update and why I'm beginning to be convinced this is actually something with the control module software...
I am convinced the fuse 5 pull and reset is not reliable, I think, why? Every time you pull that an reseat it goes straight to full tank. Now if this is a problem due to a faulty level sensor I'm not 100% sure, why, because once the code is permanent(fuel level sensor has an open circuit, short circuit) if I use the MD802 to clear the code it reads the correct level! But... Pull the fuse, 1/1 all the time.
Another thing, once you get a correct reading, in a few minutes of driving it starts to dip out to 0, if in the course of that dip you get the amber light flashing then with some luck you may just get the guage read correctly and start dipping again.
If you clear code shortly after the last code wipe, Amber light flashes, gauge doesn't respond but after some more miles, clear the code, you get a correct reading. Then ... It begins to drop...
The fact that it reads correctly the instant you send the dtc clear command is indicative that the gauge works properly.. Any thoughts? I will take some resistance readings and post up here again.
The software version is 05/01, anyone know of an updated software for the instrument cluster?
Kent
noetico is offline
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
Taxpayers are spending over $1 billion to send refined fuel to the Israeli military C_R Off-Topic 38 09-13-2012 05:54 AM
1992 400E Warms Up, Dies, Cools Off, Starts bigforkbrett W124 E,CE,D,TD Class 11 07-20-2012 09:11 AM
Bosch K-Jetronic Overview isthisdave R/C107 SL/SLC Class 13 04-09-2012 05:56 PM
OBDII Scanners and Simple Sensor Diagnostics AC_ML W163 M-Class 2 03-24-2008 10:11 AM
