98 ML 320 Issues after Battery is replaced - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 05-02-2019, 01:50 PM Thread Starter
Date registered: May 2019
Vehicle: 1998 ML320
Quoted: 2 Post(s)
Hello All,
I have a 1998 ML320 that is having some gremlins after i replaced the battery. Specifically, it is not running. It will start, for about a second, then die. I am wondering if the transponder in the steering column may have gone out? I am thinking this because its almost as if the car wants to run, but is being shut off. There aren't any trouble codes coming up and i am about 50 miles away from the nearest Mercedes mechanic that could take a look.
on a side note the key that came with the car had the top of another key taped to it. I am guessing that was due to the cost of getting a chipped key programmed to the vehicle, by the original owners.I have been using it like that for a few months and was thinking about replacing the key before the transponder switch, except i think the switch is cheaper.
Any help whatsoever would be greatly appreciated.
teraldo79 is offline
post #2 of 13 (permalink) Old 05-02-2019, 01:59 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 767 Post(s)
Do you have Start Error coming up in the cluster odometer.
Sounds like the key is not being read by the key sinc ring around the ignition. Youíll need to order a Mickey Mouse valet key.
mattml430 is online now
post #3 of 13 (permalink) Old 05-02-2019, 03:49 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
"Start Error" on odometer does not come into play until model 2001. Only indication of key not being recognized is no LED blink from ATA indicator.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 13 (permalink) Old 05-02-2019, 03:52 PM
mattml430's Avatar
Quoted: 767 Post(s)
My 2000 430 did, unless it was only export that did it maybe.
post #5 of 13 (permalink) Old 05-02-2019, 06:36 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
So, in your case what has triggered this error?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 13 (permalink) Old 05-02-2019, 06:46 PM
mattml430's Avatar
Quoted: 767 Post(s)
When I was fitting the keyless go and I didnít have the chip close enough to the ring.
I ended up taping and gluing it to the outside of the ring after I pulled it out of the key fob.
Witek_M likes this.
post #7 of 13 (permalink) Old 05-02-2019, 06:46 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
In OP case it is not what happened after battery replacement. It is what has happened before.
An attempt was made to start the car, battery died in the process. An incomplete new code was written to the key. Now there is a mismatch between the key and immobilizer.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 13 (permalink) Old 05-02-2019, 06:49 PM
mattml430's Avatar
Quoted: 767 Post(s)
Yer ok, I was thinking because he said he had 2 key fobs tapped together it may not of read the chip correctly because it was to far away.
post #9 of 13 (permalink) Old 05-02-2019, 06:59 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 775 Post(s)
OK, Got it.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 13 (permalink) Old 05-02-2019, 09:56 PM Thread Starter
Vehicle: 1998 ML320
Quoted: 2 Post(s)
So from what you're saying, neither replacing the key, nor replacing the ring would help. What solution is there to be had?
How can I tell if repair shop actually replaced my battery? BenzDawg W204 C-Class 1 06-09-2014 06:30 PM
New Battery "Quirk"? akent99 C209/A209 CLK-Class 30 05-08-2014 01:07 PM
Battery light alternator replaced twice sethwm2 W123 E,CE,D,CD,TD,TE Class 2 08-28-2012 08:27 PM
charging system problem w140 s500 alternator battery convenience module issues antonio garcia W140 S-Class 9 10-12-2010 04:32 PM
Starting problems Ericeclass W210 E-Class 38 05-23-2008 07:47 AM
