2004 ML500 AC or Compressor issue - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-19-2019, 04:42 PM Thread Starter
Date registered: Sep 2015
Hello,
Thanks in advance!
I got a 2004 ML500, absolutely love it. I am having an issue with the AC. It seems like multiple things could be going wrong. Not sure.
I took it to a Mercedes mechanic, he evacuated and recharged the system. Issue remained. He also attached a diagnose tool, couldn't see any code.
My vehicle I believe does not have a clutch on the compressor. Also it does not have a fuse for the A/C or the compressor. It has a fuse for the whole instrument controller on the passenger side kick fuse box. I checked it and it is good.
I did not hear a clicking sound on relay 26 when I turned the AC on. I checked the relay, it is good. So I read the voltage across terminals 30-87, when relay unplugged. I do not have a 12V sitting there like I do for the other relays. That seems like a problem to me. What could be the case?
Any other suggestions?
Thanks!
mebugayan is offline
post #2 of 6 (permalink) Old 04-19-2019, 04:50 PM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 783 Post(s)
Whats the actual issue your having.
He must of had the compressor running to successfully charge the system.
Does your cooling fan run any quicker once the air is turned on and the engine is at temp.
mattml430 is online now
post #3 of 6 (permalink) Old 04-19-2019, 04:57 PM Thread Starter
I do not have cold air, it is warm. I do not feel any RPM change or load change on the vehicle when I turn the AC on.
He said he recharged the system. That's all I know.
What do you think of the Relay 26, not having 12V?
Which one is the cooling fan? If it is the one right behind the radiator, it did not run when I turned the AC on.
Thank you!
post #4 of 6 (permalink) Old 04-20-2019, 06:46 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 842 Post(s)
Thank you!
What is description on fuse box legend for relay K26?
Compressor has soft start. You will not feel load change. Radiator suction fan comes on only when needed.
After recharge what ware the pressures Hi/Lo? Did that jive with readout of life data from the scanner? Scanner will show compressor demand as percentage. What was it?
https://www.benzworld.org/forums/w16...?highlight=ACC
dlafever likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #5 of 6 (permalink) Old 04-23-2019, 04:22 PM
dlafever's Avatar
Date registered: Jan 2004
Vehicle: 2010 E350 P1/P2, 2008 S550 Designo, 2002 ML320
Quoted: 106 Post(s)
Send a message via AIM to dlafever Send a message via Yahoo to dlafever
This! Because the refrigerant is metered internally in the compressor, it is possible to have a charged system but no cooling.
dlafever is offline
post #6 of 6 (permalink) Old 04-23-2019, 08:49 PM
Motivational Poster
cmitch's Avatar
Date registered: Apr 2005
Vehicle: 2002 ML320, 2005 S430 4MATIC RIP, 2010 F150 Crew Cab
Quoted: 332 Post(s)
I'm having a similar issue with my 2002. I have to press the off/reset button and then cut it back on to get it running, sometimes twice. Try that.
2005 S430 4Matic 'Morton' W220.183 722.671 Rest in Peace
Bells and whistles are thorns and thistles.
cmitch is offline
ML500 2004 Front BUmper Cover Removal - stuck halfway through cal123 W163 M-Class 30 12-22-2017 02:09 PM
Engine partout - 2003 S55/E55 M113K (5.4L supercharged) - heads, crank, pistons, more Michael Whitney For Sale/Wanted/Trade/Giveaway 5 04-14-2015 10:34 AM
ML500 2004 noisy lifters ? Maybe Not sure ? Bysouthmy04 W163 M-Class 15 11-17-2011 07:48 PM
Did Cheney forge the "Niger" document? FeelTheLove Off-Topic 23 11-03-2005 01:02 PM
7000 / 6600 Gs SOLD IN 2003/.2004 , Why close the line? Zé Bocaina G-Class 3 06-17-2005 08:40 PM
