Inner Tie rod change torque procedure/spec? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-17-2019, 07:41 PM Thread Starter
Date registered: Nov 2011
Vehicle: 03 ml350
Quoted: 16 Post(s)
Hi,
I have play in the outer tie rod. Last time I have replaced it (on the other side) I have disconnected from the inner.
That was major pain in the "derriere".
This time I will just replace them together.
I have a question regarding how do you apply the required torque on the inner to disassemble/assemble to the shaft coming from the steering rack. Do you need to hold with another wrench to counter all that torque?
I have heard that you may need to disconnect opposite bellow to gain access and put a wrench there. But wouldnt this possibly undo the side you don't want? (where you counter hold from)...
I am just concerned with the copious amount of torque if this wouldnt be damaging to the steering rack and overall wondering what the proper procedure is.
Also, is blue loctite required? I imagine I would see traces of it on the threads of the original one (if it's original).
Thanks a bunch!!
PS:nvm, I have found there are some flats on the left side of the rack, suppose to hold with a 24mm wrench from there.
I will try to make some pics with this
johnd89 is offline
post #2 of 6 (permalink) Old 04-19-2019, 06:30 PM Thread Starter
Vehicle: 03 ml350
Quoted: 16 Post(s)
Follow up,
Disconnected the inner from the outer after noticing that inner had no play.
Also noticed one style of the tool to hold the rack and no way I could find it to buy or borrow. Will improvise something when the inners will let go.
johnd89 is offline
post #3 of 6 (permalink) Old 04-20-2019, 01:36 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1519 Post(s)
Here are the procedures. Make sure you pay attention to the highlighted area in pdf #1.
43sqd is offline
post #4 of 6 (permalink) Old 04-20-2019, 06:58 PM Thread Starter
Vehicle: 03 ml350
Quoted: 16 Post(s)
Thanks so much for the procedure!
My bellows looked good so left in place.
I did noticed that the oem bellows kit come with the bellow and the two collars but also an o-ring and a small tube of grease.
Where is the grease used?
Thanks again
johnd89 is offline
post #5 of 6 (permalink) Old 04-20-2019, 07:36 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 777 Post(s)
You put grease on the ball of inner tie rod end.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 6 (permalink) Old 04-21-2019, 07:03 PM Thread Starter
Vehicle: 03 ml350
Quoted: 16 Post(s)
Thank you!
johnd89 is offline
Tie Rod replacing ... Hints to separate joints? cwmoser R/C107 SL/SLC Class 20 12-20-2018 06:25 PM
tie rod end rubber boot replacement jftu105 W124 E,CE,D,TD Class 23 12-29-2017 06:00 AM
4x4 and lockers How it works on GW463? rey445588 G-Class 5 02-04-2008 11:10 AM
Now how did my tie rod go back in 4 months!?!?!?! stabmaster W123 E,CE,D,CD,TD,TE Class 4 06-24-2006 06:03 PM
Tie rod torque seetings John Kuchta W140 S-Class 2 08-11-2004 02:46 PM
