Starter / solinoid wire issue - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 04-11-2019, 06:20 AM Thread Starter
Date registered: Apr 2019
Vehicle: 2004 C32AMG and 2000 ML430
Quoted: 2 Post(s)
Hello, new to the forum!
I have a 2000 ML430, no start condition. Pulled off the inner fender liner and found two wires bad ( small wire to solinoid broken and braided wire from starter to solinoid broken).
Obviously I need to replace the starter and repair the solinoid wire - HOWEVER....
I had a friend help me run a test on the starter circuit. I put a test light on the small wire that goes to the solinoid, when he turns the key to start, the test light LIGHTS, when he released the key, the light stayed lite for about five seconds (5)!?!?
I assume that I have a a worn part in the key area.....any thoughts on what part returns the key to the run position from the start position? Procedure to remove?
Fyi - I have taken apart countless Asian vehicles....this seems very different. I'd appreciate any tips, tricks, part #'s and /or procedures.
I currently have the plastic surround pieces off the column and pulled off the large black plastic plug with wires from the back.....next?????
Thanks in advance! Joel
jlipper81 is offline
post #2 of 7 (permalink) Old 04-11-2019, 06:28 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1498 Post(s)
Please UPDATE YOUR PROFILE in USER CP to include the year, model & where you live.
43sqd is offline
post #3 of 7 (permalink) Old 04-11-2019, 06:31 AM
Repair the solenoid wire, but new starter is required when the braided wire is damaged.
mattml430 likes this.
43sqd is offline
post #4 of 7 (permalink) Old 04-11-2019, 09:03 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 711 Post(s)
This is normal operation of "tip start" Engine control module will hold starter engaged until engine starts or about up to 10 seconds.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #5 of 7 (permalink) Old 04-11-2019, 09:32 AM Thread Starter
Quoted: 2 Post(s)
Profile updated
post #6 of 7 (permalink) Old 04-11-2019, 12:43 PM Thread Starter
Quoted: 2 Post(s)
Wow, really? If this is the case, does that mean the starter is spun with the engine for up to 10 seconds? Would seem to me that it would burn up a starter quicker that way. I thought it immediately retracted after releasing the key??????
post #7 of 7 (permalink) Old 04-11-2019, 01:20 PM
mattml430's Avatar
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 742 Post(s)
I think you miss understand. It will run the starter for up to 10 seconds in a non engine starting situation to prevent starter over heating. As soon as the engine starts the starter stops.
You do not need to hold the key in the start position. Turn it to start and let it go. It will do the rest.
Noodles and Witek_M like this.
mattml430 is offline
Starter motor pj2009 W140 S-Class 5 03-21-2018 03:58 AM
Mystery starter issue for my 89 300CE [email protected] W124 E,CE,D,TD Class 3 12-08-2016 07:40 AM
2003 A-Class wont start jn_nz W168 A-Class 51 08-16-2013 01:19 PM
Suspension Down, Transmission Fault, Now Won’t Start! - 230v petrol automatic kristoofar V-Class 12 10-30-2012 03:42 PM
Starter Issue 97 E320 deserte320 W210 E-Class 2 12-12-2009 06:28 PM
