Interior lights - Mercedes-Benz Forum
post #1 of 45 (permalink) Old 04-05-2019, 08:13 AM Thread Starter
Date registered: Mar 2019
Quoted: 4 Post(s)
Interior lights
Help
I am having trouble troubleshoting what should be a simple problem
No map lights rear passenger lights. Found two bad fuses and still no lights. May of been created by me after shorting tailgate light when one of bulb holder springs broke
Its a *2000 mercedes ml320*. Thank you in advance
Ttwerie is offline
post #2 of 45 (permalink) Old 04-05-2019, 12:51 PM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1530 Post(s)
When you say map lights, do you mean the one at the grab handles?
What fuse numbers were blown?
What bulb were you working on, stop, signal, etc. and what side?
43sqd is offline
post #3 of 45 (permalink) Old 04-05-2019, 01:32 PM Thread Starter
Quoted: 4 Post(s)
I will get back to you on the numbers. It was a 15 amp in the engine compartment and a 10 amp in the interior of the car on the passenger side. The interior one I don’t think had anything to do with it it was the cigarette lighter. Anyway the problem started when I was changing a bulb in the tailgate section interior and the clip broke and shorted to ground I am assuming Saw slight spark checked the fuses 15 amp was blown changed it and now my overhead pushbutton map lights rear pushbutton passenger lights by the grab handle all not working. More info to follow. Pouring in Ny so cant look now
Ttwerie is offline
post #4 of 45 (permalink) Old 04-05-2019, 01:34 PM Thread Starter
Quoted: 4 Post(s)
If you have a diagram picture available of the interior fuse box I will tell you the fuse . Thabk you
Ttwerie is offline
post #5 of 45 (permalink) Old 04-07-2019, 12:01 AM
If you know what fuses were blown, why can't you go back to those fuse boxes and look at the charts?
It appears that you want to make it easier for yourself.
43sqd is offline
post #6 of 45 (permalink) Old 04-07-2019, 04:29 AM Thread Starter
Quoted: 4 Post(s)
Hi, I had said it was pouring rain out in previous post sorry for misunderstanding
F13 and F41 were blown. Let me add i just purchased ml320 and changing bulb on tailgate interior light lead to problem.
Ttwerie is offline
post #7 of 45 (permalink) Old 04-07-2019, 08:12 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 828 Post(s)
Here is location of fuse F2f2 for cigarette lighter.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 45 (permalink) Old 04-07-2019, 09:49 AM Thread Starter
Quoted: 4 Post(s)
Yes that one was blown also in interior compartment but unreated to issue with interior lights I believe? Like i said just found when checking for lighting issue and think was like this for a while before i purchased
Ttwerie is offline
post #9 of 45 (permalink) Old 04-07-2019, 10:01 AM
And you did not answer this question..............What bulb were you working on, stop, signal, etc. and what side?
43sqd is offline
post #10 of 45 (permalink) Old 04-07-2019, 10:07 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 828 Post(s)
Interior lights get power from F1f13, map lights in the interior mirror F1f31.
Have you played with any other bulbs?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
