ML55, Refurbishment in Process - Mercedes-Benz Forum
post #1 of 38 (permalink) Old 11-23-2018, 08:00 PM Thread Starter
Date registered: Nov 2018
Vehicle: ml55, ml63, AMG GT (soon..)
Quoted: 19 Post(s)
Cool ML55, Refurbishment in Process
I thought I would say hello. Got this truck recently, and looking to bring it to its former glory.
2000 ML55 ... paid almost nothing for it. engine purrs... not a single tick... engine is 100% top shape. Transmission as well.
THINGS I HAVE DONE (last week) (with help of my mechanic):
1. Oil and Transmission Fluid Change
2. Brake pads - PAGID... HUGE DIFFERENCE
3. Bleeding the Brakes, obviously
4. Bleeding them some more.....
5. Replaced Brake Master Cylinder (that one i didn't do, but...)
6. Replaced the Motor Mounts ! <-- i did that !
7. Replaced Torsion Tube plastic thingies <-- I didn't do that
8. Blacked out grill holes (leaving chrome bars and chrome emblem intact)
CURRENTLY (this week):
1. Took Center Console out for deep cleaning and removed 18 years of dirt
2. Refurbished Ashtray - and trying to figure out if possible to attach a deeper compartment extending down through the ashtray. (chop chop)
3. Refurbished / fixed glove box
4. Replacing useless passenger cup holder
5. Installing Rear Seat cigarette lighter (below/part of cup holder trim) - in process (I might do a writeup)
6. Headlight Restoration
7. replacing any engine lines that look worn out
8. Front Right Fender Flare missing
ARRANGING NOW (2 weeks):
1. Sunroof R&R
2. Rear Wiper troubleshooting
3. Replace machine gun door latch (in Rear, luckily)
4. Check AC valve? Blower only blows heat..so,,, something might be stuck
5. replace power steering fluid reservoir
6. flush coolant system
7. Bluetooth module install (waiting to hear back from 2 vendors)
8. Trailer Hitch
9. Mud flaps all around
FUTURE (2 months):
1. OEM Bi-Xenon, will get Euros
2. Mercedes Eclass LED DRL's install
3. Billstein Front shocks
4. repaint calipers - to AMG metallic bronze or silver
5. dual AMG tips? and resonator delete
6. New AMG/ML500 front bumper (previous owner put on a ML320 bumper I think. blasphemy!)
7. LED Mirror Indicators
8. PDC?
9. Removing all side trim and headliner, and replacing with Alcantara (ps: car will be going off the beaten path... but.... alcantara.... I will have it)
10. Alcantara middle seat inserts for fronts (maybe for rears)
11. Matte Black Powdercoat OEM Nerf Bars
12. control arms (!$$)
13. Clear Coat or Sandpaper... I can't decide...
ID:	2467740   Click image for larger version
mattml430 and khomer2 like this.
amgdvl is offline
post #2 of 38 (permalink) Old 11-23-2018, 08:07 PM Thread Starter
Quoted: 19 Post(s)
Anyone have the following lying around / doing nothing :
1. Trailer Hitch
2. Front Right Fender Flare
3. Spare Tire support / mount (I have the carrier, and a tire.. but the metal bracket it mounts to is missing)
4. Rear Cargo Cover (ML55)
5. Mud flap set...I have something lined up.. but wondering if anyone might have a set / part of a set for cheaper
6. Mirror Covers with LED turn signals - OEM or Knockoff? Suggestions
7. Passenger Cup Holder (black)
amgdvl is offline
post #3 of 38 (permalink) Old 11-24-2018, 11:34 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 236 Post(s)
alpinadvl,
nice find.
(1) no rear cig lighter at the bottom of your center console (rear side) on the 2000 model year? humm, I would have presumed there was a cig tray at the bottom there (it's on the 2002 models...)
(2) check to see if the 2002 model year oem side mirror covers will fit. They have blinkers.
(3) I'd keep the calipers as red. it's oem, right?
khomer2 is online now
post #4 of 38 (permalink) Old 11-24-2018, 01:24 PM Thread Starter
Quoted: 19 Post(s)
Originally Posted by khomer2 View Post
alpinadvl,
nice find.
that would be an n-ope just a lot of wasted plastic taking up an unnecessary amount of space !
have seen plenty of write-ups on it. I am only curious if I can get my side blinkers to work in addition to the LED mirror indicators. (otherwise I have a useless "hole" / reflector)
its OEM, red brembos...yes. was thinking more along the lines in the pic attached (just not as dirty)
red for me is on a ferrari or a porsche... just doesn't work in my head on a Merc.
amgdvl is offline
post #5 of 38 (permalink) Old 11-24-2018, 01:38 PM Thread Starter
Quoted: 19 Post(s)
Grill Mod Done
** disclaimer ** I am not responsible for how nice your grill will look after this... but i am sure you will enjoy it !
quick and dirty writeup :
1. remove grill - screws on back... do not detach hood release latch!... you can tilt the grill at an angle...and the latch passes through the opening in the grill
2. clean it. dry it. blow dry it if you want (careful around chrome,...that will peel)... but it has to be dry... dry... and clean...
3. prep / remove some trim:
a. remove the chrome mercedes star - there are 2 tabs on the back, i think at 3' and 9' that need to be nudged out of the way with a thin flat screw driver... then just rotate the emblem counterclockwise (or clockwise)..
b. optional: remove the upper, silver painted machine gun hole trim: there are tabs that hold it in place on the back (this will make at least one of the trims easier to paint. I think you can remove all the machine gun trim.. but i didn't mess around with it)..
to remove: just ease the tab up a little with a thin flat head.. one at a time... just have patience... it will come out (don't put too much pressure, or the tabs might break... mine didnt, and i put some pressure on it... just a warning for others, just in case)
4. masking. use painters tape to cover the chrome trim bars... this will take the most time... but it is pretty easy. the only part that is a bit of a pain is the bottom of the circle that holds the emblem... use a sharp knife to trace around the indent and cut out excess tape for that area.
note: I had to repaint that trim black, because its color had changed... you might not want to "freshen up" your already black trim on the grill... if that's the case... you just saved 10 mins.
5. painting time... ventilated area...garage door open. I used rustoleum matte black high temp spray paint (home depot)... its specifically for engine covers, hoods, and grills...
- spray lightly... uniform passes.... focus specifically on the "hard to reach spots".... but don't overdo it... this is not a race... wait an hour... and spray gently again.... repeat again an hour later if necessary (look at the piece with light shining at off angle just to make sure you didn't miss any spots)
6. hardest part : wait 24 hours for full curing... its cold temp near me... so I will just wait 48 hours for the hell of it.
Final Result (not on car yet!) :.
amgdvl is offline
post #6 of 38 (permalink) Old 11-24-2018, 02:39 PM
Date registered: Jan 2005
Vehicle: 1999 ML430
Quoted: 191 Post(s)
Thats an aggressive game plan ! She is a beauty, how about some interior shots ?
How many miles on her ? Looks to be in great shape.
The MOST important thing you can do to keep her running well is to change oil every 5,000-10,000 miles. Everybody's got their favorite elixir, but Mobil One 0W40 is the clear overall winner. And of course change filter with a FLEECE filter with every oil change.
Oh, Welcome Aboard !!!
springerfever is offline
post #7 of 38 (permalink) Old 11-24-2018, 04:31 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 840 Post(s)
Originally Posted by alpinadvl View Post
[B]
[B][U]
Get it under the blanket, get your partner going. It will cure in 20 minutes.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 38 (permalink) Old 11-24-2018, 06:27 PM
mattml430's Avatar
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 783 Post(s)
Those brakes look to be of a ML63. The 55 came out with red callipers originally.
Itís a beautiful looking 55.
mattml430 is online now
post #9 of 38 (permalink) Old 11-24-2018, 08:44 PM Thread Starter
Quoted: 19 Post(s)
Thanks. 130k miles. First thing I did was change the oil and trans fluid. Mechanic recommended 5w-30....then 5w-30 after 5-10k miles to "flush out" any residue / sediment etc.... .... then 0w-40 or 5w-40 from then on.
Thanks... outside needs freshening up... but that will happen last. That picture is from ML63...yeah..I know ml55 OEM is red... but... I just have a different pref. Might also consider metallic silver... with "AMG" stickers on them.
amgdvl is offline
post #10 of 38 (permalink) Old 11-25-2018, 08:47 PM Thread Starter
Quoted: 19 Post(s)
done today:
  • sunroof refurbished (removed, cleaned, greased, adjusted)
  • all parameters (adaptation values) on car "reset"
  • headlight restoration - impossible to really see...but looks factory new... tried to get a pic at night... but its impossible to capture the xenon light properly
  • installed modded grill (see above)
  • passenger seat fixed (got lucky on that one...loose connector)
pics (enjoy) :
ID:	2468104   Click image for larger version
ID:	2468106   Click image for larger version
arnoldmir93 likes this.
amgdvl is offline
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
leeadrian75 , johnma
