AAC as of 09/2002 - Mercedes-Benz Forum
post #1 of 53 (permalink) Old 08-12-2018, 09:53 AM Thread Starter
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 900 Post(s)
ACC as of 09/2002
Wiring diagram and legend.
mercbentz likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #2 of 53 (permalink) Old 08-12-2018, 10:00 AM Thread Starter
Witek_M's Avatar
Vehicle: 1972
Quoted: 900 Post(s)
Here is sensor readout using Autel MD802 Elite all systems.
Conditions: Vehicle parked overnight in the garage. Key on everything else off. Purpose of this readout is sanity check of temperature sensors. They all should read about the same (+/- 2).
---------------------1 of 12 Frame---------------------
041 N22b1 (In-car temperature 27.0 C
sensor)
042 Blower voltage in rear 0 V
043 B10/6 (Evaporator 25 C
temperature sensor)
044 B12/2 (Refrigerant pressure 7 bar
and temperature sensor)
045 B12/2 (Refrigerant pressure 28 C
046 B10/7 (Rear outlet air 26 C
temperature sensor)
047 B10/25 (Front footwell 27 C
outlet air temperature sensor)
048 B10/24 (Center vent outlet 27 C
094 A9 (AC compressor) 0 %
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 53 (permalink) Old 08-12-2018, 10:14 AM Thread Starter
Witek_M's Avatar
Vehicle: 1972
Quoted: 900 Post(s)
Another sensor readout. Short trip around the block then idle in P. Condenser fans cycling. Temperature dial at minimum, blower on 3 of 5.
---------------------1 of 11 Frame---------------------
041 N22b1 (In-car temperature 18.0 C
sensor)
042 Blower voltage in rear 6 V
043 B10/6 (Evaporator 3 C
temperature sensor)
044 B12/2 (Refrigerant pressure 14 bar
045 B12/2 (Refrigerant pressure 104 C
046 B10/7 (Rear outlet air 9 C
temperature sensor)
047 B10/25 (Front footwell 5 C
048 B10/24 (Center vent outlet 4 C
094 A9 (AC compressor) 100 %
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 53 (permalink) Old 08-12-2018, 11:33 AM
Date registered: May 2009
Vehicle: 2000 Mercedes Benz ML320
Quoted: 87 Post(s)
Interesting....
That's "all" parameters, as opposed to "selected" parameters, right?....
There is a "Rear Blower Voltage" heading and value, which does not explicitly mention M2/1, and there is NO separate heading for Front Blower Voltage which would be A32, or A32/m1, and value.... and no heading for M13
Wonder if that is selected from the Body systems Menu as "N22" or AAC subsystem sensors, and if there is any additional A/C subsystem live data that would include the mentioned missing parameters above ?
mercbentz
mercbentz is offline
post #5 of 53 (permalink) Old 08-12-2018, 12:21 PM Thread Starter
Witek_M's Avatar
Vehicle: 1972
Quoted: 900 Post(s)
Amount of available data is mind boggling. Here is some from A32. I have run blower from 0% to 100" in 0.5 steps.
A32m1 @0%
---------------------1 of 33 Frame---------------------
090 A32m1 (Blower motor) : 0 %
Specified value:
091 A32m1 (Blower motor) : REACHED
Actual value
092 M2/1 (Rear blower motor) : 0 %
Specified value:
281 A32n1 (Blower regulator) : INACTIVE
Short circuit cutoff
282 A32n1 (Blower regulator) : INACTIVE
Maximum current limit
283 A32n1 (Blower regulator) : INACTIVE
100 %
284 A32n1 (Blower regulator) : INACTIVE
Overload - Shutoff
285 A32n1 (Blower regulator) : OK
Temperature
287 Under- or overvoltage INACTIVE
detection (supply voltage)
288 Output stage INACTIVE
289 A32n1 (Blower regulator) : 0 A
Current consumption of component
290 A32n1 (Blower regulator) : 33 C
Temperature
291 Supply voltage A32 (Heating 14.5 V
systems recirculated air unit)
A32m1 @54%
---------------------24 of 33 Frame---------------------
090 A32m1 (Blower motor) : 54 %
Specified value:
Actual value
092 M2/1 (Rear blower motor) : 43 %
Specified value:
100 %
Overload - Shutoff
Temperature
288 Output stage ACTIVE
289 A32n1 (Blower regulator) : 8 A
Temperature
291 Supply voltage A32 (Heating 14.3 V
A32m1 @100 %
---------------------33 of 33 Frame---------------------
090 A32m1 (Blower motor) : 100 %
Specified value:
Actual value
Specified value:
283 A32n1 (Blower regulator) : ACTIVE
100 %
Overload - Shutoff
Temperature
289 A32n1 (Blower regulator) : 25 A
Temperature
291 Supply voltage A32 (Heating 13.9 V
Noodles and mercbentz like this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 53 (permalink) Old 08-12-2018, 01:10 PM
Quoted: 87 Post(s)
That's good to hear, it is in fact Excellent.
One does not have to touch any wires, or connectors, other than the Scanner's to connect to the car and get the data for a full comprehensive picture waiting comfortably in the driver's seat.......
mercbentz
post #7 of 53 (permalink) Old 08-12-2018, 01:20 PM Thread Starter
Witek_M's Avatar
Vehicle: 1972
Quoted: 900 Post(s)
There is still room for interpretation but at least you can get some info without braking out DVM.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 53 (permalink) Old 08-12-2018, 02:19 PM
Quoted: 87 Post(s)
What is great about the car systems is that once the Diagnostics have properly started, the scanner acts almost as a Screen for the computer in the CU, with the CU virtually dumping data to the scanner's screen with the same content, and possibly format, regardless what is the scanner, Autel, SDS, or whatever....
mercbentz
post #9 of 53 (permalink) Old 08-14-2018, 09:03 AM
Quoted: 87 Post(s)
I've forgot about M13, and M2/2, which could be helpful to connect to the other thread. They're probably in the crowd.
mercbentz
post #10 of 53 (permalink) Old 08-14-2018, 11:17 AM Thread Starter
Witek_M's Avatar
Vehicle: 1972
Quoted: 900 Post(s)
mercbentz
ACC live data is divided into 11 groups. I have not gone through all of them.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
