Differential Locker? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 05-16-2018, 07:07 PM Thread Starter
Date registered: Jul 2012
Vehicle: 2000 ML320
Quoted: 34 Post(s)
Took my ML for a camping trip and got stuck in some lose sand. Luckily I got winched out by a friendly Tacoma driver. It was pretty sad that I got stuck on such a small gradient sandy incline. I recently got brand new Michelin defenders mud/snow tires. So not much help there. Low range didn't help either. So of course I checked the search function for anyone installing a rear diff locker and seems like no one has? Is there a reason why this hasn't been done yet?
LegendaryATM is offline
post #2 of 6 (permalink) Old 05-17-2018, 03:43 AM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
Quoted: 647 Post(s)
Probably because it's in the same category as adding a turbocharger to a gasoline-powered ML. Expensive, unnecessary and ill-advised. Yet there are dreamers who want to do this stuff, just because.
Modern electronic traction-control systems have made diff lockers obsolete.
Did you deflate your tires, to under 21 psi?
DrX is online now
post #3 of 6 (permalink) Old 05-17-2018, 03:48 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 96 Post(s)
Not sure that will help you. The traction control will give you the same effect, but if all 4 wheels are spinning on ice or sand, it’s winch time.
Hirnbeiss is offline
post #4 of 6 (permalink) Old 05-17-2018, 04:21 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 774 Post(s)
Should of turned off the ESP in sand. Probably would of come out. As DrX said tyre pressure is also important in sand I use to run about 15psi.
mattml430 is offline
post #5 of 6 (permalink) Old 05-17-2018, 03:20 PM
DrX
DrX's Avatar
Quoted: 647 Post(s)
Originally Posted by Hirnbeiss View Post
... if all 4 wheels are spinning on ice or sand, itís winch time.
Unless you're obstructing traffic, on soft sand there are other strategies before deploying the winch.
  • Deflate your tires - if you have the balls you can go down to 12 psi for tubeless. Make sure ESP is off.
  • Dig from around the bogged tires, insert sticks or firewood for traction.
  • Jack up one corner, putting wood under the jack. Fill in the hole, add water to compact the sand. Repeat on opposite corner.
There are some sand driving tips translated from German at this link:
https://www.benzworld.org/forums/w163...l#post10076161
For next time.
DrX is online now
post #6 of 6 (permalink) Old 05-22-2019, 01:14 AM
Jonathan Kucyj's Avatar
Date registered: Apr 2019
Vehicle: 01 ML430
Quoted: 6 Post(s)
Obsolete? I beg to differ. I'd much rather know I have power going 50/50 front/rear like the old school t-cases. And a rear locker will get you over some obstacles in 2wd that you cant do in 4wd. These aren't rock crawlers but I'd be ashamed if I got stuck like that LOL. I'm working on a fix because that will not be me.
The ML will be awesome in snow with independent front and rear suspension. I'd blaze trail for SAS rigs because all they'd do was bulldoze snow up front and I only had my rear axle dragging.
Jonathan Kucyj is offline
