ML350 Offroad Capable? - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 07-11-2016, 05:22 PM Thread Starter
Date registered: Jul 2016
I have a 2004 ML350 and have lightly tested its offroad capability. Some of my friends with better off-road cars want to do a trip, but I am unsure how my stock ML350 will hold up. My questions are how off-road capable is it, and what modifications would be necessary to make it more capable in rough conditions.
Nanobot4000 is offline
post #2 of 25 (permalink) Old 07-12-2016, 12:56 AM
mattml430's Avatar
Date registered: Sep 2008
Vehicle: 2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
Quoted: 806 Post(s)
Find out where they want to go and do some research on the area. Clearance and tyres would be the only drawback if original. But generally the ML will probably surprise your friends. With the ESP if you loose traction it will brake that wheel and transfer the power to the others.
mattml430 is offline
post #3 of 25 (permalink) Old 07-12-2016, 09:16 AM Thread Starter
Yeah I have new tires with better traction and I'm debating increasing the clearance on the car
post #4 of 25 (permalink) Old 07-12-2016, 11:33 AM
pdxgrease's Avatar
Date registered: May 2009
Vehicle: 05 ML500 SE
Quoted: 12 Post(s)
For off-roading I would try going from stock diameter tires (29") to something about 31.5". That would get you a lot more clearance and tire protection without fitment issues.
current:
2005 ML500 SE Black on Black
gone but not forgotten:
'04 Cayenne S, '99 ML 430, '99 C43 AMG, '07 X3, '06 2500 diesel, '02 gti, '02 tdi (tuned), '85 300 td, 86 300TDT, '85 SDL, '81 AMC Eagle Wagon, '76 240d
pdxgrease is offline
post #5 of 25 (permalink) Old 07-12-2016, 12:40 PM
mattml430's Avatar
Quoted: 806 Post(s)
W163 lift kit rear spacers 20mm or 10mm ZINC ELECTRO PLATED STEEL
https://r.tapatalk.com/shareLink?url...7&share_type=t
post #6 of 25 (permalink) Old 07-12-2016, 07:37 PM
Vehicle: 1990 190E 2.6,.... 1998 ML320, 2005 ML500SE
Quoted: 95 Post(s)
Matt, I think you meant 4ETS not ESP.
Mike's ML is offline
post #7 of 25 (permalink) Old 07-12-2016, 07:39 PM
mattml430's Avatar
Quoted: 806 Post(s)
Yes your rite Mike , thanks.
post #8 of 25 (permalink) Old 07-12-2016, 09:45 PM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
Quoted: 649 Post(s)
Once you've removed the rear mudflaps (where fitted), you're good to go offroad without lifting the body or putting on bigger tires.
As long as your ML350 is not SE with running boards, that reduce ground clearance somewhat.
DrX is offline
post #9 of 25 (permalink) Old 07-12-2016, 10:09 PM
Date registered: Jul 2011
Vehicle: 03 ML350
Quoted: 34 Post(s)
Also, stay away from steep inclines that require you to spin the wheels very fast to get to the top.
Even when turned off, the ESP kicks in and will stop you dangerously on the slope with no option but to go back in reverse.
gotca is offline
post #10 of 25 (permalink) Old 07-13-2016, 07:29 AM
Quoted: 95 Post(s)
If you deactivate ESP it stays off but 4ETS is always active and will both brake spinning wheals and reduce power.
Mike
