DTC P185800 & 1858-002??? - Mercedes-Benz Forum
post #1 of 18 (permalink) Old 09-12-2014, 06:08 PM Thread Starter
Date registered: May 2008
Vehicle: 1972 450SL, 2014 ML350
Quoted: 5 Post(s)
I have searched the site, the web, and am still trying to figure this out.
1998 ML320
CEL on
Intermit ETS and ABS
My new i980 iCarsoft scanner gives me:
P110108
P185800
P1858-002
P170300
P170302
As far as I can figure:
P110108 = right front wheel speed sensor
and now the probs begin:
P185800: ratio of HFM sensor signal to intake manifold pressure out of range
P1858-002 =?
P170200= ?
P170302= ?
Can anyone help me out with these?
What needs to be replaced to address "ratio of HFM etc ..."
Thanks for your time,
Alex
Last edited by Halexb; 09-12-2014 at 06:10 PM. Reason: Titlle should read P1858-002
Halexb is offline
post #2 of 18 (permalink) Old 09-13-2014, 12:48 AM
Date registered: Aug 2006
Vehicle: 02 ML320 06 ML500
Quoted: 1543 Post(s)
You have been a member since 2008 and never visited this site before?
Please UPDATE YOUR PROFILE in USER CP.
43sqd is offline
post #3 of 18 (permalink) Old 09-13-2014, 01:46 AM
None of the codes you posted are "P" codes. You must be reading them incorrectly or the scanner is spitting out in invalid codes.
43sqd is offline
post #4 of 18 (permalink) Old 09-13-2014, 10:03 AM Thread Starter
Quoted: 5 Post(s)
That makes sense. I'll recheck.
Thanks,
Alex
Halexb is offline
post #5 of 18 (permalink) Old 09-14-2014, 08:53 AM Thread Starter
Quoted: 5 Post(s)
"Upgraded" code reader.
Cleared DTC log.
Drove car ~20miles.
Error P0130
Will check right front O2 sensor. It may not be connected any longer... since I replaced the exh system.
Thanks for the help!
Alex
Halexb is offline
post #6 of 18 (permalink) Old 10-01-2014, 04:37 PM Thread Starter
Quoted: 5 Post(s)
Repl. right front wheel speed sensor:
ETS/ABS light out. Brake shudder gone.
Repl. O2 sensor.
CEL on
P0170 DTC
Repl MAF (Bosch)
Drive, clear codes, so far so good... no lights.
Thanks to you all for a great site!
and now 35,000 more miles till that 1M KM badge...
Halexb is offline
post #7 of 18 (permalink) Old 10-02-2014, 01:46 PM Thread Starter
Quoted: 5 Post(s)
Ooops now CEL on again. P0170 and P0713
Short term trim bouncing all over the place (i980 Scanner)... Long term climbing (6.1 and rising)
Time to look for leaks
Halexb is offline
post #8 of 18 (permalink) Old 10-03-2014, 04:50 AM
Fuel trim readings are supposed to rise and fall constantly. Start looking for vacuum leaks.
43sqd is offline
post #9 of 18 (permalink) Old 11-02-2014, 03:49 PM Thread Starter
Quoted: 5 Post(s)
I addressed a bad seal on throttle body to intake duct. Cleaned and resealed cyl head valve cover vents.
Replaced MAF (Bosch), fuel pump and fuel filter. Replaced loose (leaking?) brake vac hose to intake manifold clip/seal.
Went thru 3 cans of brake cleaner looking for vac leaks.... engine is now cleaner but could not detect any vacuum leaks.
Missed my annual regestration due to MIL ... but still looking for what is causing the remaining P0170.
Thanks again for assistance.
Quite frustrating
Halexb is offline
post #10 of 18 (permalink) Old 11-03-2014, 02:42 AM
So now you are saying that there is only code P0170?
43sqd is offline
